I had installed Ubuntu 14.04 x64 recently on my Toshiba with Inter Core i3 and 2Gb of RAM. My CPU supports 64bit OS.
The 64bit installer finished faster compared to when I installed the 32bit version of 14.04. I'm not sure but I think the graphics are far more crisp than the graphics of 32bit. However, the system seems to run very slow on a 64bit. I know that when you run a 64bit OS, you should have more than 2Gb of RAM which this PC doesn't have. HOWEVER, when I looked at the system monitor, it doesn't even consume more than 60% of my RAM but it still runs slow. Why is that?
And how can I get the best out of my 64bit CPU architecture on a 2gb of RAM if that will always be the case?
Jye Ramirez
  • 145
I had the same issue, go into terminal:
Type:
top
It will show a list of processes.
then type:
c
c is to sort by CPU.
If you see Apport at the top with 98% CPU it's glichted.
Here is how to disable it: How do I enable or disable Apport?
