31
Is there any switch to tell top command in order to one time scan the system and do not monitor it all time?
Dan
  • 6,784
The -n switch is what you search:
user@host:~$ top -n 1
See the manpage
   -n : Number of iterations limit as:  -n number
        Specifies the maximum number of iterations, or frames, top should produce before ending.
If you want to stop top command just press q.
Notice: If you tend to use top in a script, I need to say top is not meant for scripts, use ps instead.
Pandya
  • 37,289
chaos
  • 28,186
12
notice that if you would like to keep "top" command for a script, you could use -b option ("-b" option means "batch mode operation"), this option allows you to redirect the output into a file.
Examples:
  • top one shoot batch mode : top -bn 1 2>&1 1> /tmp/topN
  • top sorted by memory usage one shoot batch mode : top -ban 1 2>&1 1> /tmp/topAN
boly38
  • 223
