I want to run top so that it opens as if you hit the m key, what I really want is this:
How to run ''top'' command 1 time and exit?
But I want to
a) have the 'm' key hit b) sort by memory (shift-m)
Can this be done from the command line?
Thanks, Kevin
update - showing what i am seeking from command line without having to hit any key:
Just an update to clarify i need BOTH the sort by AND the memory showing, in a single command line, the given solution only solves the sort request. Thanks for any help.
user1130176
  • 203
  • 13
from command line you can sort with -o. On MEM this would be
top -o +%MEM
if from high to low.
See man top:
-o :Override-sort-field as: -o fieldname Specifies the name of the field on which tasks will be sorted, independent of what is reflected in the configuration file. You can prepend a + or - to the field name to also override the sort direction. A leading + will force sorting high to low, whereas a - will ensure a low to high ordering.
This option exists primarily to support automated/scripted batch mode operation.
Rinzwind
  • 309,379
