I've updated my Ubuntu 14.04 with GNOME/GTK 3.12 (because I want to test drive GNOME and play with some recent GNOME applications), but as a result, all GNOME application now use client side decorations also when running under my default KDE workspace.
Is there a way to disable the GTK+ 3.12 default use of CSD outside GNOME shell?
Guss
  • 3,775
You could try gtk3-nocsd: article on WebUpd8
sudo add-apt-repository ppa:nilarimogard/webupd8
sudo apt-get update
sudo apt-get install gtk3-nocsd
Add the following to your "~/.profile"
export GTK_CSD=0
export LD_PRELOAD=/path/to/gtk3-nocsd.so
The author an WebUpd8 writes, that Unity doesn't start with that, so you can edit a .desktop file in /usr/share/applications, for example gthumb:
/usr/share/applications/gthumb.desktop
Add the follwing to "Exec=":
env LD_PRELOAD=/usr/lib/gtk3-nocsd/gtk3-nocsd.so
so that it looks like this:
Exec=env LD_PRELOAD=/usr/lib/gtk3-nocsd/gtk3-nocsd.so gthumb %U
iCON
  • 36
