172
I just installed the LAMP stack on my Ubuntu system.
The redirection is not working for me. I don't know how to fix it. Can anyone help me?
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
vinoth
  • 1,821
To enable it the rewrite module, run "apache2 enable module rewrite":
sudo a2enmod rewrite
You need to restart the webserver to apply the changes:
sudo service apache2 restart
If you plan on using mod_rewrite in .htaccess files, you also need to enable the use of .htaccess files by changing AllowOverride None to AllowOverride FileInfo. For the default website, edit /etc/apache2/sites-available/default:
    <Directory /var/www/>
            Options Indexes FollowSymLinks MultiViews
            # changed from None to FileInfo
            Order allow,deny
            allow from all
    </Directory>
After such a change, you need to restart Apache again.
Lekensteyn
  • 178,446
51
I dare to add a special answer (as a followup to the great answer above) regarding ubuntu 14.04 and .htaccess :
In 14.04, the name of the default configuration file is changed to 000-default.conf :
sudo gedit /etc/apache2/sites-available/000-default.conf
add the following to the end of the file :
<Directory "/var/www/html">
    AllowOverride All
</Directory>
For some reason, in Ubuntu 14.04 and apache2 the root is set to /www/html. If you want to change the webserver root back to good old /www, open 000-default.conf and change
DocumentRoot /var/www/html/
to
and then off course it should be
<Directory "/var/www">
    AllowOverride All
</Directory>
davidkonrad
  • 731
  • 16
