I am trying to install cakephp ( a php framework) which requires to enable mod_rewrite. For this I followed Enable mod_rewrite answer. But after restarting my server It says:
nitish@nitish-G31T-M7:~$ service apache2 restart
Restarting web server apache2 /usr/sbin/apache2ctl: 87: ulimit: error
setting limit (Operation not permitted) apache2: Could not reliably
determine the server's fully qualified domain name, using 127.0.1.1
for ServerName /usr/sbin/apache2ctl: 87: ulimit: error setting limit
(Operation not permitted) apache2: Could not reliably determine the
server's fully qualified domain name, using 127.0.1.1 for ServerName
(13)Permission denied: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down Unable to open logs
**Action 'start' failed.**
The Apache error log may have more information.
What this means? How can I enable mod_rewrite ?
Nitish
  • 103
Did you remember to use sudo with the restart command?
If not, you have to have superuser abilities (sudo) to restart Apache. Try using sudo service apache2 restart instead. You need the superuser abilities to shut down the current instance, and then to start up a new one and bind to port 80.
Thomas Ward
  • 78,878
