I have 3 hardrives inside my laptop 2 of which currently house other opperating systems but have a empty partitions of 8 and 9 gigabye and the third is just 12 gB (currently not partitioned at all). Now each of these 3 is to small to be useful to me, however combined they are 29gigs which can easily hold a ubuntu installation, and associated programs. Is there a way set up my installation in such a way that it threads these 3 disks as one? Or is there a way by which I can make it default storage of many things into one drive (downloads and sudo apt-get install for example) to one drive while keeping ubuntu onto another?
bain
  • 12,200
Thijser
  • 1,101
  • 14
  • 39
You could do it with LVM as documented here and here. But 14.04 now supports btrfs, so I would give that a try:
  • Make a partition on each disk to take up the free space
  • mkfs.btrfs -d single /dev/sdxx /dev/sdyy /dev/sdzz
  • If you want to check the filesystem, do mount /dev/sdxx /mnt; df -h; umount /mnt - df will show the total space of all three devices
  • In Ubuntu installer, select manual partitioning ("something else"), select your btrfs filesystem (any of the 3 devices), set type "btrfs" and mount point "/". Do not check the "format?" checkbox. Click "install now" - the installer will warn "The filesystem... has not been marked for formatting", just click continue.
  • Do the rest of the install as normal
For further details on this approach see Btrfs wiki - Using btrfs with multiple devices.
bain
  • 12,200
