I fail at configuring a second monitor using Mini-Display-Port > HDMI cable > ASUS MX279 on Ubuntu 14.04, Dell XPS 13 Dev. Edition (latest Intel HD4000 drivers installed). Out of the box it worked first, then signal disappeared. I rebooted, signal disappeared again and did not reappear. (Also connection to monitor is no longer established).
Then I followed these instructions: Can I force VGA signal output even when xrandr shows 'disconnected'?
It did not work (cannot configure CRC1). I changed HDMI cable to pricier one, no success. I searched 3 hours for solutions and did not find a particular one to be used for a newbie like me... any ideas?
Suggest switching mini dp adapter.
I originally tried using an Apple Brand mini dp to vga adapter without success. I bought a StarTech (mini dp to 1 HDMI) and it solved my problem.
I've also used the StarTech mini dp to multi (VGA/HDMI/DVI) successfully.
