Since I've upgraded from ubuntu 13.04 to 14.04 (and before 13.10) my system get's to it's knees when the memory get's full and has to start swaping..
Of course I know that a performance penalty should occur, but this is too much.. even the pointer stops working for a few seconds and one time I had to manualy reboot the notebook (I wasn't unable to switch to a console with ALT+Fx to kill some process). This usually happens with Google Chrome when I go to far opening tabs and I have a few other apps running, still I expect from linux to behave much better than this and I think this started happening since 13.10 an 14.04.
I'm using "System Load Indicator" (by Hofmann) and when the memory get's full the cpu load get's to 100% and if I don't start inmediately to close stuff, caos is inevitable.
Here is my notebook hardware specification:
lenovou310
    description: Laptop
    product: IdeaPad U310 (System SKUNumber)
    vendor: LENOVO
    version: Lenovo U310
    serial: QTF0E423807536
    width: 64 bits
    capabilities: smbios-2.7 dmi-2.7 vsyscall32
    configuration: administrator_password=unknown boot=normal chassis=laptop family=IDEAPAD U310 frontpanel_password=unknown keyboard_password=unknown power-on_password=unknown sku=System SKUNumber uuid=0062E5DD-80C0-047A-BBC8-089E0131C789
  *-core
       description: Motherboard
       product: Lenovo
       vendor: LENOVO
       physical id: 0
       serial: QB06137476
       slot: Part Component
     *-firmware
          description: BIOS
          vendor: LENOVO
          physical id: 5
          version: 65CN15WW
          date: 06/05/2012
          capacity: 6592KiB
          capabilities: pci upgrade shadowing cdboot bootselect edd int5printscreen int9keyboard int14serial int17printer int10video pc98 acpi usb biosbootspecification netboot uefi
     *-cpu
          description: CPU
          product: Intel(R) Core(TM) i5-3317U CPU @ 1.70GHz
          vendor: Intel Corp.
          physical id: 0
          bus info: cpu@0
          version: Intel(R) Core(TM) i5-3317U CPU @ 1.70GHz
          serial: To Be Filled By O.E.M.
          slot: CPU Socket - U3E1
          capacity: 782MHz
          width: 64 bits
          clock: 100MHz
          capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm ida arat epb xsaveopt pln pts dtherm tpr_shadow vnmi flexpriority ept vpid fsgsbase smep erms cpufreq
          configuration: cores=2 enabledcores=2 threads=4
        *-cache:0
             description: L1 cache
             physical id: 2
             slot: L1-Cache
             capacity: 32KiB
             capabilities: internal write-through instruction
        *-cache:1
             description: L2 cache
             physical id: 3
             slot: L2-Cache
             capacity: 256KiB
             capabilities: internal write-through unified
        *-cache:2
             description: L3 cache
             physical id: 4
             slot: L3-Cache
             capacity: 3MiB
             capabilities: internal write-back unified
     *-cache
          physical id: 1
          slot: L1-Cache
          capacity: 32KiB
          capabilities: internal write-through data
     *-memory
          description: System Memory
          physical id: 36
          slot: System board or motherboard
        *-bank:0
             description: SODIMM DDR3 Synchronous 1600 MHz (0,6 ns)
             product: SHARETRONIC
             vendor: 0000
             physical id: 0
             serial: EDD60803
             slot: ChannelA-DIMM0
             width: 64 bits
             clock: 1600MHz (0.6ns)
        *-bank:1
             description: DIMM [empty]
             physical id: 1
             slot: ChannelB-DIMM0
     *-pci
          description: Host bridge
          product: 3rd Gen Core processor DRAM Controller
          vendor: Intel Corporation
          physical id: 100
          bus info: pci@0000:00:00.0
          version: 09
          width: 32 bits
          clock: 33MHz
        *-display
             description: VGA compatible controller
             product: 3rd Gen Core processor Graphics Controller
             physical id: 2
             bus info: pci@0000:00:02.0
             version: 09
             width: 64 bits
             clock: 33MHz
             capabilities: msi pm vga_controller bus_master cap_list rom
             configuration: driver=i915 latency=0
             resources: irq:45 memory:f0000000-f03fffff memory:e0000000-efffffff ioport:3000(size=64)
        *-usb:0
             description: USB controller
             product: 7 Series/C210 Series Chipset Family USB xHCI Host Controller
             physical id: 14
             bus info: pci@0000:00:14.0
             version: 04
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi xhci bus_master cap_list
             configuration: driver=xhci_hcd latency=0
             resources: irq:40 memory:f0600000-f060ffff
        *-communication
             description: Communication controller
             product: 7 Series/C210 Series Chipset Family MEI Controller #1
             physical id: 16
             bus info: pci@0000:00:16.0
             version: 04
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi bus_master cap_list
             configuration: driver=mei_me latency=0
             resources: irq:43 memory:f0615000-f061500f
        *-usb:1
             product: 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2
             physical id: 1a
             bus info: pci@0000:00:1a.0
             version: 04
             width: 32 bits
             clock: 33MHz
             capabilities: pm debug ehci bus_master cap_list
             configuration: driver=ehci-pci latency=0
             resources: irq:16 memory:f0619000-f06193ff
        *-multimedia
             description: Audio device
             product: 7 Series/C210 Series Chipset Family High Definition Audio Controller
             physical id: 1b
             bus info: pci@0000:00:1b.0
             version: 04
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi pciexpress bus_master cap_list
             configuration: driver=snd_hda_intel latency=0
             resources: irq:46 memory:f0610000-f0613fff
        *-pci:0
             description: PCI bridge
             product: 7 Series/C210 Series Chipset Family PCI Express Root Port 1
             physical id: 1c
             bus info: pci@0000:00:1c.0
             version: c4
             width: 32 bits
             clock: 33MHz
             capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
             configuration: driver=pcieport
             resources: irq:16
        *-pci:1
             product: 7 Series/C210 Series Chipset Family PCI Express Root Port 2
             physical id: 1c.1
             bus info: pci@0000:00:1c.1
             version: c4
             width: 32 bits
             clock: 33MHz
             resources: irq:17 ioport:2000(size=4096) ioport:f0400000(size=1048576)
           *-network
                description: Ethernet interface
                product: RTL8101E/RTL8102E PCI Express Fast Ethernet controller
                vendor: Realtek Semiconductor Co., Ltd.
                physical id: 0
                bus info: pci@0000:02:00.0
                logical name: eth0
                version: 05
                serial: 08:9e:01:31:c7:89
                capacity: 100Mbit/s
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
                configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl_nic/rtl8105e-1.fw latency=0 link=no multicast=yes port=MII speed=10Mbit/s
                resources: irq:41 ioport:2000(size=256) memory:f0404000-f0404fff memory:f0400000-f0403fff
        *-pci:2
             product: 7 Series/C210 Series Chipset Family PCI Express Root Port 3
             physical id: 1c.2
             bus info: pci@0000:00:1c.2
             version: c4
             width: 32 bits
             clock: 33MHz
             resources: irq:18 memory:f0500000-f05fffff
           *-network
                description: Wireless interface
                product: Centrino Wireless-N 2200
                physical id: 0
                bus info: pci@0000:03:00.0
                logical name: wlan0
                version: c4
                serial: 9c:4e:36:74:fc:9c
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
                configuration: broadcast=yes driver=iwlwifi driverversion=3.13.0-29-generic firmware=18.168.6.1 ip=192.168.1.126 latency=0 link=yes multicast=yes wireless=IEEE 802.11bgn
                resources: irq:44 memory:f0500000-f0501fff
        *-usb:2
             product: 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1
             physical id: 1d
             bus info: pci@0000:00:1d.0
             version: 04
             width: 32 bits
             clock: 33MHz
             resources: irq:23 memory:f0618000-f06183ff
        *-isa
             description: ISA bridge
             product: HM77 Express Chipset LPC Controller
             physical id: 1f
             bus info: pci@0000:00:1f.0
             version: 04
             width: 32 bits
             clock: 33MHz
             capabilities: isa bus_master cap_list
             configuration: driver=lpc_ich latency=0
             resources: irq:0
        *-storage
             description: SATA controller
             product: 7 Series Chipset Family 6-port SATA Controller [AHCI mode]
             physical id: 1f.2
             bus info: pci@0000:00:1f.2
             version: 04
             width: 32 bits
             clock: 66MHz
             capabilities: storage msi pm ahci_1.0 bus_master cap_list
             configuration: driver=ahci latency=0
             resources: irq:42 ioport:3088(size=8) ioport:3094(size=4) ioport:3080(size=8) ioport:3090(size=4) ioport:3060(size=32) memory:f0617000-f06177ff
        *-serial UNCLAIMED
             description: SMBus
             product: 7 Series/C210 Series Chipset Family SMBus Controller
             physical id: 1f.3
             bus info: pci@0000:00:1f.3
             version: 04
             width: 64 bits
             clock: 33MHz
             configuration: latency=0
             resources: memory:f0614000-f06140ff ioport:efa0(size=32)
     *-scsi:0
          physical id: 2
          logical name: scsi0
          capabilities: emulated
        *-disk
             description: ATA Disk
             product: SanDisk SSD U100
             physical id: 0.0.0
             bus info: scsi@0:0.0.0
             logical name: /dev/sda
             version: 10.5
             serial: 123703305383
             capabilities: partitioned partitioned:dos
             configuration: ansiversion=5 sectorsize=512 signature=a157f07e
           *-volume:0
                description: EXT4 volume
                vendor: Linux
                physical id: 1
                bus info: scsi@0:0.0.0,1
                logical name: /dev/sda1
                logical name: /
                version: 1.0
                serial: 1d689f36-584e-43fa-9913-9fba14388fe6
                capacity: 18GiB
                capabilities: primary bootable journaled extended_attributes large_files huge_files dir_nlink recover extents ext4 ext2 initialized
                configuration: created=2013-10-15 21:14:43 filesystem=ext4 lastmountpoint=/ modified=2014-06-11 19:46:24 mount.fstype=ext4 mount.options=rw,relatime,errors=remount-ro,data=ordered mounted=2014-06-11 19:46:24 state=mounted
           *-volume:1
                description: Linux swap volume
                physical id: 2
                bus info: scsi@0:0.0.0,2
                logical name: /dev/sda2
                version: 1
                serial: 08b19113-2637-4773-bd5a-f29e84f437d9
                capacity: 3924MiB
                capabilities: primary nofs swap initialized
                configuration: filesystem=swap pagesize=4096
     *-scsi:1
          physical id: 3
          logical name: scsi1
        *-disk
             product: ST500LT012-9WS14
             vendor: Seagate
             physical id: 0.0.0
             bus info: scsi@1:0.0.0
             logical name: /dev/sdb
             version: 0001
             serial: W0V201JA
             configuration: ansiversion=5 sectorsize=4096 signature=a157f067
           *-volume
                vendor: Linux
                physical id: 1
                bus info: scsi@1:0.0.0,1
                logical name: /dev/sdb1
                logical name: /media/hdd2
                version: 1.0
                serial: 277ade7b-18eb-4b1c-9bc5-53c523e71eb1
                capacity: 465GiB
                capabilities: primary journaled extended_attributes large_files huge_files dir_nlink recover extents ext4 ext2 initialized
                configuration: created=2013-10-15 21:14:47 filesystem=ext4 lastmountpoint=/media/hdd2 modified=2014-06-11 19:46:26 mount.fstype=ext4 mount.options=rw,relatime,data=ordered mounted=2014-06-11 19:46:26 state=mounted
  *-battery
       product: Smart Battery
       vendor: Intel Corp.
       physical id: 1
       version: 2008
       serial: 1.0
       slot: Rear
  *-power UNCLAIMED
       description: TBD by ODM
       product: TBD by ODM
       vendor: TBD by ODM
       physical id: 2
       version: 1.0
       serial: TBD by ODM
       capacity: 32768mWh
Any directions how to diagnose or solve this issue? Thanx!
----- EDIT1 ------
Ok, I will expand according to request, I set up a simple batch file to log system usage every 2 secs:
#!/bin/bash
STAMP=$(date +"%H_%M_%S")
echo -e "** memory usage **\n" >> $STAMP
free -mh >> $STAMP
echo -e "\n** top 20 process by memory usage **\n" >> $STAMP
ps aux --sort -rss | cut -c-120  | head -n 20 >> $STAMP
echo -e "\n** top 10 process by cpu usage **\n" >> $STAMP
ps aux --sort -c | cut -c-110  | head -n 10 >> $STAMP
echo $STAMP
Then I've run it with watch every 2 secs and started toying around..
This is a snapshot of my system at moment zero, I have a bunch of apps open but everything is smooth:
** memory usage **
             total       used       free     shared    buffers     cached
Mem:          3,7G       3,5G       221M       458M        49M       914M
-/+ buffers/cache:       2,6G       1,2G
Swap:         3,8G       321M       3,5G
USER       PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
pablo     6649  0.0  7.7 885004 303968 ?       Sl   jun12   0:29 zeus command: server
pablo    12849  0.4  5.6 1143948 221364 ?      Sl   jun12   3:23 /usr/lib/thunderbird/thunderbird
pablo     6219  0.4  5.0 1320524 196468 ?      Sl   jun12   7:33 /opt/google/chrome/chrome --type=gpu-process --channel=
pablo     6606  0.0  4.2 448240 166980 pts/24  Sl+  jun12   0:00 zeus slave: test_helper
pablo     6578  0.0  4.0 430084 159872 pts/24  Sl+  jun12   0:02 zeus slave: test_environment
pablo     6581  0.0  3.8 478248 149860 pts/24  Sl+  jun12   0:02 zeus slave: development_environment
pablo     6599  0.0  3.8 479336 148716 pts/24  Sl+  jun12   0:00 zeus slave: prerake
pablo     6646  0.0  3.7 478248 148372 ?       Ssl  jun12   0:03 zeus runner: server
pablo     6183  0.7  3.7 1110824 148172 ?      SLl  jun12  12:44 /opt/google/chrome/chrome
pablo     2467  1.3  3.1 1747564 122460 ?      Sl   jun11  25:31 compiz
pablo     6573  0.0  3.0 361908 119024 pts/24  Sl+  jun12   0:01 zeus slave: default_bundle
pablo     6497  0.0  2.7 341316 106412 pts/24  Sl+  jun12   0:00 zeus slave: boot
pablo    21267  0.5  2.3 1065768 89972 ?       Sl   02:34   0:06 /opt/google/chrome/chrome --type=renderer --lang=en-US
pablo    21500  1.5  2.1 1057900 82376 ?       Sl   02:46   0:06 /opt/google/chrome/chrome --type=renderer --lang=en-US
pablo    21337  0.4  1.9 1053920 77052 ?       Sl   02:38   0:04 /opt/google/chrome/chrome --type=renderer --lang=en-US
pablo    21620  1.9  1.9 1049320 76592 ?       Sl   02:50   0:03 /opt/google/chrome/chrome --type=renderer --lang=en-US
pablo    21404  0.6  1.9 1051528 74452 ?       Sl   02:41   0:04 /opt/google/chrome/chrome --type=renderer --lang=en-US
root      1330  0.8  1.8 441088 72656 tty7     Ssl+ jun11  16:03 /usr/bin/X -core :0 -seat seat0 -auth /var/run/lightdm/
pablo    19127  0.0  1.7 1036788 70244 ?       Sl   jun12   0:07 /opt/google/chrome/chrome --type=renderer --lang=en-US
pablo    21211  1.1  1.5 1022532 59316 ?       Sl   02:30   0:15 /opt/google/chrome/chrome --type=renderer --l
pablo    21379  1.0  0.6 802196 26116 ?        Ssl  02:40   0:08 gvim snapshot
pablo    21285  0.9  0.6 969072 24564 ?        Sl   02:34   0:10 /opt/google/chrome/chrome --type=ppapi --chan
pablo    21482  0.9  1.7 1039728 68976 ?       Sl   02:45   0:04 /opt/google/chrome/chrome --type=renderer --l
This is a snapshot of my system under heavy load, actually opening multiple chrome tabs, almost without response:
** memory usage **
Mem:          3,7G       3,6G       155M       455M        17M       693M
-/+ buffers/cache:       2,9G       866M
Swap:         3,8G       347M       3,5G
pablo     6649  0.0  7.6 885004 299060 ?       Sl   jun12   0:29 zeus command: server
pablo    21816 49.3  7.3 1215860 285332 ?      Sl   02:53   0:13 /opt/google/chrome/chrome --type=renderer --lang=en-US
pablo     6219  0.4  5.8 1336344 229096 ?      Rl   jun12   7:37 /opt/google/chrome/chrome --type=gpu-process --channel=
pablo    12849  0.4  5.6 1143948 221360 ?      Sl   jun12   3:23 /usr/lib/thunderbird/thunderbird
pablo     6606  0.0  4.2 448240 166936 pts/24  Sl+  jun12   0:00 zeus slave: test_helper
pablo     6183  0.8  3.8 1244608 148912 ?      SLl  jun12  12:54 /opt/google/chrome/chrome
pablo     2467  1.3  3.0 1747256 119924 ?      Sl   jun11  25:34 compiz
pablo    21958 44.0  2.1 1051856 83236 ?       Sl   02:53   0:02 /opt/google/chrome/chrome --type=renderer --lang=en-US
pablo    21500  1.4  2.1 1057900 82364 ?       Sl   02:46   0:06 /opt/google/chrome/chrome --type=renderer --lang=en-US
pablo    21620  1.6  1.9 1049320 76504 ?       Sl   02:50   0:03 /opt/google/chrome/chrome --type=renderer --lang=en-US
pablo    21337  0.4  1.9 1049824 75236 ?       Sl   02:38   0:04 /opt/google/chrome/chrome --type=renderer --lang=en-US
pablo    21404  0.6  1.9 1051528 74320 ?       Sl   02:41   0:04 /opt/google/chrome/chrome --type=renderer --lang=en-US
pablo    21958 44.0  2.1 1051860 83236 ?       Sl   02:53   0:02 /opt/google/chrome/chrome --type=renderer --l
pablo    22012 25.0  1.0 988364 42900 ?        Sl   02:53   0:00 /opt/google/chrome/chrome --type=renderer --l
pablo    21211  1.0  1.5 1022532 59316 ?       Sl   02:30   0:15 /opt/google/chrome/chrome --type=renderer --l
pablo    21285  0.9  0.7 979840 30956 ?        Sl   02:34   0:11 /opt/google/chrome/chrome --type=ppapi --chan
Why is chrome using all that CPU when the memory starts to get full? Even if chrome is the "culprit", isn't the OS responsability to stay operable under heavy load?
Add more memory, if possible.
General information about low memory: Preventing low memory problems (windows specific, but the concepts are similar)
The Linux kernel provides a tweakable setting that controls how often the swap file is used, called 'Swappiness'
Mark
  • 330
