I am posting this again because I have changed to VMWare Player and I discovered something new.
I am running Ubuntu 12.04 LTS (Guest) in VMWare Player 6.0.2 on Windows 7 64-bit Host. I have VMWare Tools installed properly.
I am running MATE but the problem persists when I change (to and from) xfce, gnome, mate a-- and back again I had been using this for a couple of years without any graphics issues. After an Ubuntu update (typical) -- my video is corrupt and will not refresh correctly.
My desktop icons are "mirrored" and when I open a terminal window (for instance) -- sometimes -- the window appears multiple times.
Of course, only one is the real image. It seems to be a refresh problem.
When I move an active window around the screen the "older" images "erase" and my icons (for instance) are in the correct location.
For instance, I can move the terminal around a pretty corrupted window and the screen behind it is repainted correctly.
NEW:
Next, I got the idea to try and Remote Desktop in to the Ubuntu 12.04 LTS Guest OS from my Windows 7 64-bit Host.
Once working, and connected via Win RDC -- using MATE as default in my /etc/xrdp/startws.sh -- my video is not corrupted and works fine (as in the past).
Any ideas about what is going on ? or how to fix this ?
bain
  • 12,200
Alex Reynolds
  • 29
I had the same "mirroring" problem after updating my vmware 64 bit Ubuntu. The previous version was fine. I fixed the problem by copying
/lib/modules/3.2.0-30-generic/kernel/drivers/gpu/drm/vmwgfx/vmwgfx.ko
to
/lib/modules/3.2.0-65-generic/kernel/drivers/gpu/drm/vmwgfx/vmwgfx.ko
After renaming the original driver under 3.2.0-65. I don't know at what version the driver broke since "30" was the previous version that I had. 32 bit Ubuntu exhibited the same problem after updating. Downgrading the driver as above fixed it as well.
user.dz
  • 49,176
Keith
