How to set ICC profile for display in Kubuntu? In System Settings - Color I can add .icc file to the device, set the checkbox. But the device does not actually use the profile. There is no apply button or something, too.No errors when run from the terminal, too. Just don't work.
For me in Kubuntu 18.04/bionic the following worked:
Install colord-kde This adds a page in the system settings devices section. There, in the profiles tab, I could install my icc profile system-wide (to /var/lib/colord/icc/).
Run colormgr get-devices-by-kind display and lookup the id of your display.
Run colormgr find-profile-by-filename /var/lib/colord/icc/<name of your icc file> to lookup the id of your profile.
Then run the following commands to connect the profile to your display and make it default:
colormgr device-add-profile <display id> <profile id>
colormgr device-make-profile-default <display id> <profile id>
I've found Nvidia blob guilty of ignoring ICC. After switching to nouveau all started working.
