TL;DR - go to the bottom of the answer, "Applying the restrictions"
Adding a restricted user consists of two parts:
1. Creating the user
2. Configuring the SSH daemon (sshd)
Configuring sshd
The best place to get known to the possibilities of SSH is by reading the related manual pages:
Where can SSH client perform actions?
Before you can restrict something, you need to know the features of SSH. Spitting through the manual pages yields:
- Shell commands execution
- File upload through sftp
- Port forwarding
- The client forwards an (un)used port to the server
- The server forwards his port to the client
- The server forwards a port of another host to the client (proxy-ish)
- X11 forwarding (display forwarding)
- Authentication agent forwarding
- Forwarding of a tunnel device
From the Authentication section of the manual page of sshd(8):
If the client successfully authenticates itself, a dialog for preparing
the session is entered. At this time the client may request things like
allocating a pseudo-tty, forwarding X11 connections, forwarding TCP
connections, or forwarding the authentication agent connection over the
secure channel.
After this, the client either requests a shell or execution of a command.
The sides then enter session mode. In this mode, either side may send
data at any time, and such data is forwarded to/from the shell or command
on the server side, and the user terminal in the client side.
Options for restricting SSH features
Files and their options that alter behavior are:
~/.ssh/authorized_keys - contains keys which are allowed to connect which can be given options:
command="command" - The command supplied by the user (if any) is ignored. Note that the client may specify TCP and/or X11 forwarding unless they are explicitly prohibited. Note that this option applies to shell, command or subsystem execution.
no-agent-forwarding - Forbids authentication agent forwarding when this key is used for authentication.
no-port-forwarding - Forbids TCP forwarding when this key is used for authentication
no-X11-forwarding - "Forbids X11 forwarding when this key is used for authentication."
permitopen="host:port" - Limit local 'ssh -L' port forwarding such that it may only connect to the specified host and port.
~/.ssh/environment - This file is read into the environment at login (if it exists). Environment processing is disabled by default and is controlled via the PermitUserEnvironment option
~/.ssh/rc - Contains initialization routines to be run before the user's home directory becomes accessible.
/etc/ssh/sshd_config - the system-wide configuration file
AllowAgentForwarding - Specifies whether ssh-agent(1) forwarding is permitted.
AllowTcpForwarding
ForceCommand - "Forces the execution of the command specified by ForceCommand, ignoring any command supplied by the client and ~/.ssh/rc if present. The command is invoked by using the user's login shell with the -c option."
GatewayPorts - "Specifies whether remote hosts are allowed to connect to ports forwarded for the client. By default, sshd(8) binds remote port forwardings to the loopback address. This prevents other remote hosts from connecting to forwarded ports. GatewayPorts can be used to specify that sshd should allow remote port forwardings to bind to non-loopback addresses, thus allowing other hosts to connect."
PermitOpen:
Specifies the destinations to which TCP port forwarding is
permitted. The forwarding specification must be one of the
following forms:
PermitOpen host:port
PermitOpen IPv4_addr:port
PermitOpen [IPv6_addr]:port
Multiple forwards may be specified by separating them with
whitespace. An argument of 'any' can be used to remove all
restrictions and permit any forwarding requests. By default all
port forwarding requests are permitted.
PermitTunnel - Specifies whether tun(4) device forwarding is allowed. The default is 'no'
X11Forwarding - Specifies whether X11 forwarding is permitted. The default is 'no'
Modifying the system-wide configuration file /etc/ssh/sshd_config allows the configuration be applied even if password-based authentication is applied or if the restrictions in ~/.ssh/authorized_keys are accidentally removed. If you've modified the global defaults, you should uncomment the options accordingly.
Match User limited-user
#AllowTcpForwarding yes
#X11Forwarding no
#PermitTunnel no
#GatewayPorts no
AllowAgentForwarding no
PermitOpen localhost:62222
ForceCommand echo 'This account can only be used for [reason]'
Now add a user:
sudo useradd -m limited-user
The option ForceCommand can be omitted if the shell is set to a non-shell like /bin/false (or /bin/true) as /bin/false -c [command] won't do anything.
Now the client can only connect to port 62222 on the loopback address of the server over SSH (it will not listen on the public IP address)
Disabling AllowTcpForwarding would also disallow the use of -R, thus defeating the use of such a restricted account for forwarding a single port. PermitOpen localhost:62222 assumes that port 62222 on the server is never in use because the client can happily connect to it and listen on it too.
If TCP forwarding is allowed in the system-wide configuration and disabled password-based authentication, you can use per-key settings as well. Edit ~/.ssh/authorized_keys and add the next options before the ssh- (with a space between the options and ssh-):
command="echo 'This account can only be used for [reason]'",no-agent-forwarding,no-X11-forwarding,permitopen="localhost:62222"
Verify
To be sure that it works as expected, some test cases need to be run. In the below commands, host should be replaced by the actual login if it's not set in ~/.ssh/config. Behind the command, a command is shown that should be executed on either the client or server (as specified).
# connection closed:
ssh host
# connection closed (/bin/date is not executed):
ssh host /bin/date
# administratively prohibited (2x):
ssh host -N -D 62222 # client: curl -I --socks5 localhost:62222 example.com
ssh host -N -L 8080:example.com:80 # client: curl -I localhost:8080
sftp host
# should be possible because the client should forward his SSH server
ssh host -N -R 8080:example.com:80 # server: curl -I localhost:8080
# This works, it forwards the client SSH to the server
ssh host -N -R 62222:localhost:22
# unfortunately, the client can listen on that port too. Not a big issue
ssh host -N -L 1234:localhost:62222
Conclusion
Checklist: The SSH user should not able to:
- execute shell commands - done
- access files or upload files to the server - done
- use the server as proxy (e.g. webproxy) - done
- access local services which were otherwise not publicly accessible due to a firewall - partially, the client cannot access other ports than 62222, but can listen and connect to port 62222 on the server
- kill the server - done
(note that these checks are limited to the SSH server. If you've an other vulnerable service on the machine, it could allow a possible attacker to run commands, kill the server, etc. )
