I'm trying to create a bootable clonezilla usb with tuxboot, the application that is recommended by clonezilla site. I installed it via Ubuntu PPA and follow the instructions on the site to put files on usb. Everything went well and then I restarted the system. Now when I'm trying to boot from usb it says: "This is not a bootable disk. Please insert a bootable floppy and press any key to try again ..." What is causing this problem?
I really appreciate any help you can provide. My laptop model is Dell studio-1558 and I'm running Ubuntu 14.04
karel
  • 122,292
  • 133
  • 301
  • 332
Jahan
  • 183
Clonezilla live USB works very well with UNetbootin (unetbootin) from the default Ubuntu repositories. Clonezilla is in UNetbootin's list of compatible distros in the UNetbootin == Select Distribution == dropdown menu. You should reformat the USB flash drive as FAT32 in GParted first if you have ever used the USB flash drive to boot a Linux distro.
UNetbootin has been dropped from the Ubuntu 18.04 repositories. When I tested the built-in Startup Disk Creator application as a UNetbootin replacement app with a Clonezilla .iso image it worked in Ubuntu 18.04. I also tested making bootable live USBs in Startup Disk Creator with 5 other ISOs that previously worked with UNetbootin including GParted and they all booted successfully.
karel
  • 122,292
  • 133
  • 301
  • 332
