I am trying to install the latest kernel 3.14.4 on my Ubuntu 14.04. But it gives me an error when I try to install using make file. I have also done the make oldconfig, it took more than 3 hours to complete, and when I try to make install, a few errors are thrown in the terminal:
VirtualBox:/home/sonyx64/Documents/linux-3.14.4# make install
sh /home/sonyx64/Documents/linux-3.14.4/arch/x86/boot/install.sh 3.14.4 arch/x86/boot/bzImage \
    System.map "/boot"
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.14.4 /boot/vmlinuz-3.14.4
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.14.4 /boot/vmlinuz-3.14.4
update-initramfs: Generating /boot/initrd.img-3.14.4
WARNING: missing /lib/modules/3.14.4
Device driver support needs thus be built-in linux image!
depmod: ERROR: could not open directory /lib/modules/3.14.4: No such file or directory
depmod: FATAL: could not search modules: No such file or directory
depmod: WARNING: could not open /tmp/mkinitramfs_Xm5CtY/lib/modules/3.14.4/modules.order: No such file or directory
depmod: WARNING: could not open /tmp/mkinitramfs_Xm5CtY/lib/modules/3.14.4/modules.builtin: No such file or directory
run-parts: executing /etc/kernel/postinst.d/pm-utils 3.14.4 /boot/vmlinuz-3.14.4
run-parts: executing /etc/kernel/postinst.d/update-notifier 3.14.4 /boot/vmlinuz-3.14.4
run-parts: executing /etc/kernel/postinst.d/zz-update-grub 3.14.4 /boot/vmlinuz-3.14.4
Generating grub configuration file ...
Warning: Setting GRUB_TIMEOUT to a non-zero value when GRUB_HIDDEN_TIMEOUT is set is no longer supported.
Found linux image: /boot/vmlinuz-3.15.0-1-generic
Found initrd image: /boot/initrd.img-3.15.0-1-generic
Found linux image: /boot/vmlinuz-3.14.4
Found initrd image: /boot/initrd.img-3.14.4
Found linux image: /boot/vmlinuz-3.14.4.old
Found memtest86+ image: /boot/memtest86+.elf
Found memtest86+ image: /boot/memtest86+.bin
done
Wilf
  • 30,732
As explained here (and here), you should be able download the deb files from http://kernel.ubuntu.com and install them.
To do this, run these commands in Terminal:
To download for 32bit:
wget kernel.ubuntu.com/~kernel-ppa/mainline/v3.14.4-utopic/linux-headers-3.14.4-031404_3.14.4-031404.201405130853_all.deb
wget kernel.ubuntu.com/~kernel-ppa/mainline/v3.14.4-utopic/linux-headers-3.14.4-031404-generic_3.14.4-031404.201405130853_i386.deb
wget kernel.ubuntu.com/~kernel-ppa/mainline/v3.14.4-utopic/linux-image-3.14.4-031404-generic_3.14.4-031404.201405130853_i386.deb
To download for 64bit
wget kernel.ubuntu.com/~kernel-ppa/mainline/v3.14.4-utopic/linux-headers-3.14.4-031404-generic_3.14.4-031404.201405130853_amd64.deb
wget kernel.ubuntu.com/~kernel-ppa/mainline/v3.14.4-utopic/linux-image-3.14.4-031404-generic_3.14.4-031404.201405130853_amd64.deb
To find your current kernel architecture (*bit), see this question
To install the downloaded deb files, run
sudo dpkg -i linux-headers-3.14.4-*.deb linux-image-3.14.4-*.deb
Then reboot.
To uninstall, run
sudo apt-get remove linux-headers-3.14.4-* linux-image-3.14.4-*
You will need to reboot and choose it in Grub to use the kernel, you can find the kernel you are currently using by running:
uname -r
Wilf
  • 30,732
