I tried to install my gpu in Ubuntu 12.04 with this link
What is the correct way to install proprietary ATI Catalyst Video Drivers (fglrx) directly from AMD?
but when I type this command line:
$sudo aticonfig --initial
I got this err:
aticonfig: No supported adapters detected
what should I must to do? any suggestion about this?
I use Ubuntu 12.04 and hp pavilion dm4-1060ea note book and ati radeon hd5460
I used this command to find out the model of my gpu card:
$lspci | grep VGA
and showed me these:
00:02.0 VGA compatible controller: Intel Corporation Core Processor Integrated Graphics Controller (rev 02)
01:00.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI Manhattan [Mobility Radeon HD 5400 Series]
Thanks
Hamid
I tried several times to do this for my wifes computer, with little success and eventually gave up!
Looking at the AMD site for the current driver, released 5/22, there are many packages that you should ensure are installed on your system to make this work:
gimp-help-en
gimp-help-common
XFree86-Mesa-libGL
libstdc++
libgcc
XFree86-libs
fontconfig
freetype
zlib
gcc
Xorg/Xserver 7.4 and above (up to 1.14)
Linux kernel 2.6 or above (up to 3.11)
glibc version 2.2 or 2.3
POSIX Shared Memory (/dev/shm) support is required for 3D applications
Most of these should be on your system already, but you should check.
Read through the driver preliminary documentation at http://support.amd.com/en-us/kb-articles/Pages/AMDCatalyst14-4LINReleaseNotes.aspx, and perhaps consider downloading the latest version of the drivers at http://support.amd.com/en-us/download/desktop?os=Linux+x86#amd-catalyst-packages.
Charles Green
  • 21,859
