In an effort to use my printer, I installed a PPA but in the end, this PPA was not necessary. Now, this PPA causes an error when updates are loaded. The update error message is the following:
W:Failed to fetch http://ppa.launchpad.net/michael-gruz/canon/ubuntu/dists/precise/main/source/Sources  404  Not Found
, W:Failed to fetch http://ppa.launchpad.net/michael-gruz/canon/ubuntu/dists/precise/main/binary-i386/Packages  404  Not Found
, E:Some index files failed to download. They have been ignored, or old ones used instead.
I looked over the web how to remove a ppa but the answers are too technical for my level of understanding. I found this line:
sudo add-apt-repository --remove ppa:whatever/ppa
but I don't know what should be put in place of the "whatever". On top of that, I can't even remember how I installed this PPA. I know I went to this page:
https://launchpad.net/~michael-gruz/+archive/canon/+packages
and somehow, followed the included instructions, without really knowing what I was doing.
According to some help pages I found, installed file in /etc/apt/sources.list.d should give me some hints:
  jockey.list                            nvbn-rm-ppa-precise.list
langdalepl-gvfs-mtp-precise.list       nvbn-rm-ppa-precise.list.save
langdalepl-gvfs-mtp-precise.list.save  precise-partner.list
michael-gruz-canon-precise.list        precise-partner.list.save
but I don't understand what to look for in this list of files. I suspect that the culprits is michael-gruz-canon-precise.list, but that doesn't help me much.
I hope I put all the necessary info here.
Thank you for your help
bain
  • 12,200
frepie
  • 585
  • 32
Run in terminal:
sudo apt-add-repository --remove ppa:michael-gruz/canon
sudo apt-get update && sudo apt-get upgrade
sudo apt-get autoremove
See also:
JoKeR
  • 7,062
You should try to fix your problem with YPPA. Here, this will help you. Use y ppa to remove any duplicate ppa or fix ppa errors after installing it.
    sudo add-apt-repository ppa:webupd8team/y-ppa-manager
    sudo apt-get update
    sudo apt-get install y-ppa-manager
answerSeeker
  • 901
  • 26
