12
I have installed Apache2, mysql, php5 and phpmyadmin on my Ubuntu 14.04 but later on mistakenly I install nginx.
Now my localhost page show me Welcome to nginx server. And the localhost/phpmyadmin link is not working.
How can I get my LAMP server back?
i removed ngnix using command
sudo apt-get remove nginx
sudo apt-get purge nginx
installing apache
sudo apache2ctl restart
but at the end on restarting apache2 i get this error
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
httpd not running, trying to start
(98)Address already in use: AH00072: make_sock: could not bind to address [::]:80
(98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
AH00015: Unable to open logs
Action 'restart' failed.
First, you need to stop nginx so it releases port 80 so that apache2 can listen to it later on.
sudo service nginx stop
Next, if nginx was installed with apt-get, it can be removed by running one of the following two commands (I explained the difference in the next paragraph).
Or
Both of them remove all package files, while the second also removes the configuration files that package had installed.
If you intend to use nginx later on with the configuration you did, use remove. Else, I would suggest using purge.
After removing nginx, you can restart apache to make sure it is listening to port 80.
If you had removed apache before installing nginx, you can re-install it with
sudo apt-get install apache2
Dan
  • 14,180
12
if after that the Welcome to nginx! page appears you can try unistall other version on nginx existing on your server with
sudo apt-get remove nginx-*
and
sudo apt-get purge nginx-*
Remove all nginx packages
sudo apt-get autoremove nginx
This works for me
sudo service apache2 restart
In my case, using Deepin, I had to do more than
the execution of the
When I finished, I realized that
that the apache had also been removed. I reinstalled with the command
And I restarted the service with
