every time i start server it gives this error...
● apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
Drop-In: /lib/systemd/system/apache2.service.d
└─apache2-systemd.conf
Active: failed (Result: exit-code) since Tue 2019-12-24 23:55:49 IST; 10ms ago
Process: 11423 ExecStart=/usr/sbin/apachectl start (code=exited, status=1/FAILURE)
Main PID: 2154 (code=exited, status=0/SUCCESS)
Dec 24 23:55:49 shantanu apachectl[11423]: AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 2401:4900:30e5:3307:2136:8a60:4eeb:ba13. Set the 'ServerName' directive globally to suppress this message
Dec 24 23:55:49 shantanu apachectl[11423]: (98)Address already in use: AH00072: make_sock: could not bind to address [::]:80
Dec 24 23:55:49 shantanu apachectl[11423]: (98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:80
Dec 24 23:55:49 shantanu apachectl[11423]: no listening sockets available, shutting down
Dec 24 23:55:49 shantanu apachectl[11423]: AH00015: Unable to open logs
Dec 24 23:55:49 shantanu apachectl[11423]: Action 'start' failed.
Dec 24 23:55:49 shantanu apachectl[11423]: The Apache error log may have more information.
Dec 24 23:55:49 shantanu systemd[1]: apache2.service: Control process exited, code=exited status=1
OUTPUT OF : sudo netstat -ltnp | grep ':80'
tcp 0 0 127.0.0.1:8080 0.0.0.0:* LISTEN 14946/unicorn maste
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 7251/nginx: worker
tcp 0 0 127.0.0.1:8082 0.0.0.0:* LISTEN 3354/sidekiq 5.2.7
tcp 0 0 0.0.0.0:8060 0.0.0.0:* LISTEN 7251/nginx: worker
