146
I want to find out the OpenGL version I'm using. I have access to Ubuntu via SSH. Which command shall I execute?
Kabumbus
  • 1,563
8 Answers8
174
To Check OpenGL Version,
glxinfo | grep "OpenGL version"
You will get the output as follows,
OpenGL version string: 1.4 (2.1 Mesa 7.7.1)
Edit:
You may have better luck with modern OpenGL just grepping for "version" instead of "OpenGL version" given the differences between the core and compat profiles, as well as the various GLSL and GLES versions:
glxinfo | grep 'version'
server glx version string: 1.4
client glx version string: 1.4
GLX version: 1.4
    Max core profile version: 4.1
    Max compat profile version: 3.0
    Max GLES1 profile version: 1.1
    Max GLES[23] profile version: 3.0
OpenGL core profile version string: 4.1 (Core Profile) Mesa 11.1.2
OpenGL core profile shading language version string: 4.10
OpenGL version string: 3.0 Mesa 11.1.2
OpenGL shading language version string: 1.30
OpenGL ES profile version string: OpenGL ES 3.0 Mesa 11.1.2
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.00
Notice that the actual version is presented by the "core profile version" (4.1), whereas the "OpenGL version" is presented as 3.0.
Tim
  • 33,500
karthick87
  • 84,513
28
depending on what you're looking for:
Open GL Implementation
You can use glxinfo, from the mesa-utils package:
sudo apt-get install mesa-utils
Development Libraries
this depends a little,
dpkg -s [package name]
will tell you version information, etc. of any package.
but you'll need to know what specific part/implementation, etc. of opengl you're interested in. i suspect, for you, it'll be:
dpkg -s libglu1-mesa
19
Note: I've added this answer at a later date, because none of the existing answers address a crucial aspects regarding ssh, and will give misleading values to those who follow the above instructions.
  1. Use X-forwarding when ssh-ing. This is enabled with ssh -X.
    Without x-forwarding:
    $ ssh MYCOMP
    $ glxinfo
    Error: unable to open display
    With x-forwarding:
    $ ssh -X MYCOMP
    $ glxinfo | grep -i opengl
    OpenGL vendor string: NVIDIA Corporation
    OpenGL renderer string: GeForce 8800 GT/PCIe/SSE2
    OpenGL version string: 2.1.2 NVIDIA 310.44
    OpenGL shading language version string: 1.20 NVIDIA via Cg compiler
    OpenGL extensions:
    I should note here that this is both the wrong graphics card, and wrong version numbers. ('Wrong' in terms of what you would expect).
  2. Set DISPLAY variable to :0, to allow access to the graphic card's driver from the remote session.
    $ ssh -X MYCOMP
    $ DISPLAY=:0
     OpenGL renderer string: GeForce GTX 550 Ti/PCIe/SSE2
     OpenGL version string: 4.3.0 NVIDIA 310.14
     OpenGL shading language version string: 4.30 NVIDIA via Cg compiler
     OpenGL extensions:
    This lists the correct graphics card (the one on the remote computer), as well as the correct version numbers.
swalog
  • 387
For those who only want the version number, for example to give it in argument of a program, you can use
$ glxinfo | awk '/OpenGL version/ {print $4}'
3.0
Note: optirun glxinfo | awk '/OpenGL version/ {print $4}' if you are using bumblebee
yakoudbz
  • 249
You can get the information by running following command:
DISPLAY=:0 glxgears -info | grep GL_VERSION
This echos something like:
GL_VERSION    = 3.3.0 NVIDIA 340.93
Also try without DISPLAY=:0 in case of problems. The command glxgears is in mesa-utils package which can be installed with:
psprint
  • 194
Type nvidia-settings and go to Graphics information > OpenGL. Look up a value of the Version: property, it's going to be something like 4.6.0 NVIDIA 450.66
daGo
  • 376
Ubuntu 17.10, open terminal and type;
You will recieve something like this;
OpenGL version string: 3.0 Mesa 17.2.2
If you receive an error that the program glxinfo is not available, you will need to enter the command
sudo apt install mesa-utils
Charles Green
  • 21,859
Psyduck
If you have root access to a remote computer running Ubuntu 16.04, you could run
user@local_computer:~$ ssh root@remote.example.com
root@remote:~# export DISPLAY=:0
root@remote:~# export XAUTHORITY=/var/lib/lightdm/.Xauthority
root@remote:~# glxinfo | grep -i "OpenGL version"
OpenGL version string: 3.0 Mesa 11.2.0
