I have a C project running in Linux using OpenGL that's managed in git. Computer X and computer Y have the same version of the code pulled from git. We'd like to send the executable to a third-party machine, Z, for running. However, only the executable built on X computer works; the one that built in the VM of the Y computer failed to run on machine Z. Console on machine Z showed - error while loading shared library: libglut.so.3: cannot open shared object file: No such file or directory.
Question: why do the same code and the same project setting yield different results?
I'm looking into the difference between the X machine and Y machine. The first thing I tried was to look into the version of the OpenGL. ref:Terminal command to show OpenGL version?
X computer:
emilylin@linux:/lib/x86_64-linux-gnu$ glxinfo | grep "OpenGL version"
VM of Y computer:
emilylin@linux:/usr/lib/x86_64-linux-gnu$ glxinfo | grep "OpenGL version"
OpenGL version string: 3.1 Mesa 21.2.6
Question: why I cannot find the gl version by using this command on X computer? Then, I looked into the executable linking path to see what I could find there. X computer:
emilylin@T:~/git/riv_port_replay_v2/Debug$ ldd ./riv_port_replay_v2
linux-vdso.so.1 (0x00007ffdbc7fc000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007b317dbd7000)
libGL.so.1 => /lib/x86_64-linux-gnu/libGL.so.1 (0x00007b317db50000)
libglut.so.3.12 => /lib/x86_64-linux-gnu/libglut.so.3.12 (0x00007b317d747000)
libGLU.so.1 => /lib/x86_64-linux-gnu/libGLU.so.1 (0x00007b317daf7000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007b317d400000)
/lib64/ld-linux-x86-64.so.2 (0x00007b317dcd3000)
libGLdispatch.so.0 => /lib/x86_64-linux-gnu/libGLdispatch.so.0 (0x00007b317d68f000)
libGLX.so.0 => /lib/x86_64-linux-gnu/libGLX.so.0 (0x00007b317d65c000)
libX11.so.6 => /lib/x86_64-linux-gnu/libX11.so.6 (0x00007b317d2c3000)
libXxf86vm.so.1 => /lib/x86_64-linux-gnu/libXxf86vm.so.1 (0x00007b317daee000)
libXi.so.6 => /lib/x86_64-linux-gnu/libXi.so.6 (0x00007b317d649000)
libOpenGL.so.0 => /lib/x86_64-linux-gnu/libOpenGL.so.0 (0x00007b317d61e000)
libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007b317d000000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007b317d296000)
libxcb.so.1 => /lib/x86_64-linux-gnu/libxcb.so.1 (0x00007b317cfd7000)
libXext.so.6 => /lib/x86_64-linux-gnu/libXext.so.6 (0x00007b317d282000)
libXau.so.6 => /lib/x86_64-linux-gnu/libXau.so.6 (0x00007b317dae4000)
libXdmcp.so.6 => /lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007b317d616000)
libbsd.so.0 => /lib/x86_64-linux-gnu/libbsd.so.0 (0x00007b317cfc1000)
libmd.so.0 => /lib/x86_64-linux-gnu/libmd.so.0 (0x00007b317cfb2000)
VM of Y computer:
emilylin@linux:~/git/remote_connect/riv_port_replay_v2/Debug$ ldd ./riv_port_replay_v2
linux-vdso.so.1 (0x00007ffc7974c000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f152923d000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f15290ee000)
libGL.so.1 => /lib/x86_64-linux-gnu/libGL.so.1 (0x00007f1529066000)
libglut.so.3 => /lib/x86_64-linux-gnu/libglut.so.3 (0x00007f1528e1d000)
libGLU.so.1 => /lib/x86_64-linux-gnu/libGLU.so.1 (0x00007f1528dab000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f1528da1000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f1528bad000)
/lib64/ld-linux-x86-64.so.2 (0x00007f1529556000)
libGLdispatch.so.0 => /lib/x86_64-linux-gnu/libGLdispatch.so.0 (0x00007f1528af5000)
libGLX.so.0 => /lib/x86_64-linux-gnu/libGLX.so.0 (0x00007f1528ac1000)
libX11.so.6 => /lib/x86_64-linux-gnu/libX11.so.6 (0x00007f1528984000)
libXi.so.6 => /lib/x86_64-linux-gnu/libXi.so.6 (0x00007f1528972000)
libXxf86vm.so.1 => /lib/x86_64-linux-gnu/libXxf86vm.so.1 (0x00007f152896b000)
libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f1528787000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f152876c000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f1528766000)
libxcb.so.1 => /lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f152873c000)
libXext.so.6 => /lib/x86_64-linux-gnu/libXext.so.6 (0x00007f1528727000)
libXau.so.6 => /lib/x86_64-linux-gnu/libXau.so.6 (0x00007f152871f000)
libXdmcp.so.6 => /lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f1528717000)
libbsd.so.0 => /lib/x86_64-linux-gnu/libbsd.so.0 (0x00007f15286fd000)
Question: do libglut.so.3 and libglut.so.3.12 make a difference in the result? Further, I went to the /usr/lib to try to find the .so itself, but couldn't find it on the X computer! So why did it print /lib/x86_64-linux-gnu/libglut.so.3.12 (0x00007b317d747000) when I couldn't find it in the /usr/lib folder? While in the VM of Y computer I found a shared library named libglut.so as expected.
Update: I also gave the same command to machine Z. It has two executables that are built from machine X and machine Y. One of them has problem linking the libglut.so. console screenshot on machine Z running ldd Any idea on what caused this to happen?
