When I play online videos, they are often interrupted with many blinks and other disturbances. Many times I was shown an error message that the flash player crashed. When I tried to install the flash plugin on the command line, this error was displayed. Can anyone help me to get out of this conflict?
$ sudo apt-get install flashplugin-installer
[sudo] password for agha:
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a'
 to correct the problem
Here’s a full log:
Ign http://in.archive.ubunutu.com trusty-updates/restricted Translation-en_IN
Ign http://in.archive.ubunutu.com trusty-updates/universe Translation-en_IN
Ign http://in.archive.ubunutu.com trusty-backports/main Translation-en_IN
Ign http://in.archive.ubunutu.com trusty-backports/multiverse Translation-en_IN
Ign http://in.archive.ubunutu.com trusty-backports/restricted Translation-en_IN
Ign http://in.archive.ubunutu.com trusty-backports/universe Translation-en_IN
Fetched 964 kB in 42s (22.4 kB/s)
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
agha@agha-GA-78LMT-USB3:~$ sudo apt-get install wine1.7 winetricks
agha@agha-GA-78LMT-USB3:~$ sudo dpkg --configure -a
dpkg: error: dpkg status database is locked by another process
agha@agha-GA-78LMT-USB3:~$ sudo apt-get install -f
Hee Jin
  • 886
The following works for me! I was trying to install the wireless driver when this error came. Had to delete the files and also the lock files.
sudo rm /var/lib/apt/lists/lock
sudo rm /var/cache/apt/archives/lock
cd /var/lib/dpkg/updates
sudo rm *
sudo apt-get update
and then you can run your apt-get install to whatever package you want to install
Aerosum
  • 311
Run sudo dpkg --configure -a and it should be able to correct itself.
or else
sudo apt-get install -f (fix broken packages) and then try running sudo dpkg --configure -a again.
You see how to install flash player in Ubuntu form following link
http://www.wikihow.com/Install-Flash-Player-on-Ubuntu
Updated Answer :
dpkg is locked, try the following solution and follow the above (link) steps to install flash palyer.
Unable to lock the administration directory (/var/lib/dpkg/) is another process using it?
Naive
  • 4,895
  • 28
  • 35
