18
I'm new to Linux. I got the "Unix And Linux System Administration Handbook" It speaks of several verisons of linux and unix, and the commands for viewing linux man pages and not specific to ubuntu.
How do I view the manpages?
nux
  • 39,152
7 Answers7
29
To view a manual page related to a package, open a terminal (press Ctrl+Alt+T together) and type:
man <package_name>
For example, to view grep's manual page, type:
man grep
This will open the manual page referring to the section numbers in the order:
1 2 3 4 5 6 7
If you want to open the manual page of a specific section, type:
man <section_number> <package_name>
For example, to open the manual page of the open() function in C, you should type:
man 2 open
More information:
Amal
  • 787
jobin
  • 28,567
@Jobin answer is perfect, I always like to add more options so Op can know it.
If you want to redirect a command man to a txt file:
man <command> > /location/file (change location and the name of file )
Another thing I would like you to know:
When for example you type man ls, you will see LS (1) at the top, numbers mean:
 (1)     User Commands
 (2)     System Calls
 (3)     Library functions
 (4)     Devices
 (5)     File formats
 (6)     Games and Amusements
 (7)     Conventions and Miscellany
 (8)     System Administration and Priveledged Commands
 (L)     Local. Some programs install their man pages into this section instead
 (N)     TCL commands
And if you want to view man pages on terminal I would prefer to use:
man <command> | less so you can view it as pages
For more options: man man
Braiam
  • 69,112
nux
  • 39,152
If using unity you can also access thru the Dash via yelp & the manpages scope
Open Dash home, type in manpages:whatever, ex. manpages:bash
Available man's will be displayed, when clicked on open in help window
The bookmark option in help when opened this way is semi useful, could be better.
doug
  • 17,212
You can also view man pages in a browser.
Install the man2html package using sudo apt-get install man2html and then navigate to http://localhost/cgi-bin/man/man2html
Parto
  • 15,647
You can use man package/command(name) and for more information about how man works try using man man
Hedwig
  • 121
Your knee-jerk reaction when trying to study about new command or config file should be:
man command
man file.conf
or
man command<Tab>
man file<Tab>
The argument to man is actually manpage name and the package maintainer is expected to add any manpages users would need. For many prolific packages, you can normally expect:
  • one manpage per command -- named exactly as the command,
  • at least one manpage about configuration files (typically named exactly as the main configuration file).
However the man page system is a huge, really rich resource. There are actually far more man pages that don't deal with particular command or even particular program. For example, the manpage system typically contains documentation of:
  • commands (section 1) but often also pages that are not directly commands eg. perlre,
  • kernel calls (section 2),
  • system library calls (section 3),
  • special system files (section 4),
  • configuration files and formats (section 5),
  • games (yes, games! .. although I've never seen anything there) (section 6),
  • miscellaneous stuff (like man 7 ascii, man 7 iso-8859-1, man 7 wireless) (section 7)
Also, packages may provide their documentation as manpage sections. For example, perl-doc adds section 3perl where you can find all its modules, OpenSSL adds 3ssl.
Not sure if it's on Ububtu, but on Fedora there is man-pages package that provides even more goods like POSIX versions of commands or system calls.
Just my 2ยข: If you type man man (i.e. looking up the manpage for man) you get:
* man (1)
man (7mp)
man (1p)
Man: What manual page do you want?
Man:
This shows you what sections are available for a given man page. You can type in 1, 7mp, 1p to view whichever fits your fancy. 1p, for example, is the manpage for the command as defined by POSIX. If you are feeling particularly lazy, you can just hit enter at the Man: prompt and it will go to the default (*) section.
You can tell man which section you want by adding the section number to your request like (looking for info on mkdir command): man 1 mkdir or man mkdir.1 or man mkdir(1)
As far as the sections, I might suggest the following guide (from man 2.10.2):
The table below shows the section numbers of the manual followed by the types of pages they contain.
section content
0 Header files (usually found in /usr/include)
1 Executable programs or shell commands
2 System calls (functions provided by the kernel)
3 Library calls (functions within program libraries)
4 Special files (usually found in /dev)
5 File formats and conventions, e.g. /etc/passwd
6 Games
7 Miscellaneous (including macro packages and conventions), e.g. man(7), groff(7), man-pages(7)
8 System administration commands (usually only for root)
9 Kernel routines [Non standard]
If you get bored w/ output you can change the pager to something like bat or use a colorizer. There are several ways to do this, just search for "how to colorize man page output" or something like that. It is worth looking over the manpage on man and on less (the default pager used by man) as it will make looking up stuff a lot easier in the future. It is good to know that you can do something even if you have to look up how some other time.
DrKC
