How do I install the final version of LibreOffice 3.4 in Ubuntu 10.10, 11.04 and the latest version of 11.10
Asked
Active
Viewed 3,582 times
Note Remove the previous version of OpenOffice or LibreOffice with this command
For OpenOffice
sudo apt-get remove openoffice*.*
For LibreOffice
sudo apt-get remove libreoffice*.*
1 - Go to; LibreOffice 3.4 Download
2 - Select Linux x86 deb or x64 deb depending on your computer
3 - Save & extract the file to ~/Desktop
4 - Rename the file as libreoffice
5 - Enter the following command into terminal and wait for the process to finish.
sudo dpkg -i ~/Desktop/libreoffice/DEBS/*.deb
6 - Run the following command to finish the installation:
sudo dpkg -i ~/Desktop/libreoffice/DEBS/desktop-integration/libreoffice3.4-debian-menus_3.4-12_all.deb
You now have Libreoffice 3.4 installed.
scouser73
- 4,344
Here: http://mygeekopinions.blogspot.com/2011/06/how-to-install-libreoffice-34-in-ubuntu.html I installed manually as: (for 11.04 but i think it would be appropriate for 10.10 or 10.04)
sudo apt-get purge libreoffice libreoffice-core(purge 3.2 version if you have 11.04)- download 3.4 debs from here: http://www.libreoffice.org/download/
- unarchive all debs to one folder (fore example ~/debs/libreoffice)
sudo dpkg -iR ~/debs/libreoffice/*.deblibreoffice3.4
r.1
- 92
