I have a problem with my Ubuntu, running 14.04 LTS.
The problem is that I'm trying to user Alt+F4 and Alt+Tab and it doesn't work, it only works with the Right Alt.
I also tried to set a new keyboard short-cut for Alt+F4 and Alt+Tab but as soon as I press Alt the short-cut is set.
The thing I noticed once I set the shortcut is that the key didn't correspond with Alt, it was a Level3 Shift.
I search all over the internet of a method to change that Level3 Shift to the normal Alt but only found solution to do the opposite.
Any suggestions?
Eek
  • 193
Try xev and xmodmap:
  1. Run the command xev then hover your mouse over the black square.
  2. Press the Alt key, and make a note of the following: My output was this (shortened): KeyPress event... keycode 64 (keysym 0xffe9, Alt_L), ... XFilterEvent returns: False
  3. The important part is the keycode: Mine was 64, but yours is probably different.
  4. Run the command xmodmap -e "keycode 64 = Alt_L" substituting 64 for whatever output you get (possibly 135 on your keyboard)
  5. This should have changed it. If it has, you then need to run the following command: xmodmap -pke >~/.Xmodmap
  6. Create a file called .xinitrc in your home folder (/home/username)
  7. In that file paste the line xmodmap .Xmodmap. This should save it forever.
See this answer for details about remapping.
My pronouns are He / Him
Tim
  • 33,500
Both of these solutions were a bit too hacky for my taste, so I dug a little deeper. The solution I found only uses dconf-editor.
Just open dconf-editor and search (ctrl+F) for xkb-options and update the value. In my case, the value associated with the xkb-options key was
['terminate:ctrl_alt_bksp','lv3:alt_switch']
The option 'lv3:alt_switch' was the one that was causing my headache. I simply changed the value to:
['terminate:ctrl_alt_bksp']
That's it!
Kris
  • 1,078
Check current layout defaults
  1. Check used layout/variant names, example my case:
    $ setxkbmap -query
    rules:      evdev
    model:      pc105
    layout:     us,us
    variant:    altgr-intl
  2. Open the file in /usr/share/X11/xkb/symbols/ with same name of layout.
    sudo nano /usr/share/X11/xkb/symbols/us
  3. Scroll down to the exact variant
    xkb_symbols "altgr-intl" {
     name[Group1]= "English (international AltGr dead keys)";
    include "level3(ralt_switch)"
  4. See if you have include "level3(ralt_switch)" (or maybe include "level3(lalt_switch)", not sure if that's possible), if so remove its line.
  5. Run to update layout
    sudo dpkg-reconfigure xkb-data
user.dz
  • 49,176
