I know that terminal can be started by Ctrl+Alt+T. But sometime users say about command-line with Ctrl+Alt+F2.
So, Is there any difference in working between them? And when should I use between them?
What is called tty?
What is called tty?
The virtual terminals (the ones you get to with Ctrl Alt F1-9) go back to the roots of Linux. Remember that Linux was originally a command-line only system and designed for multiple users. The idea was that each user could log into a single tty. This would not happen on the same physical machine of course, think of servers that many computer terminals would connect to. Each user would connect using a different computer and the server would log them into a tty.
This has nothing to do with the tty command which is part of coreutils. The tty command is simply a tool that lets you know the name of the terminal you are currently using.
The "terminal" (actually called a "terminal emulator") is simply a GUI program that mimics the old behavior. It lets you run a shell (bash in the default Ubuntu) from within your X session.
The main point is that both the virtual terminals and the terminal emulators provide you with a command line interface, a shell. They are basically the same thing. The only important difference from a practical point of view is that the terminal emulators run interactive, non-login shells while if you drop into a tty and login there, you will run an interactive, login shell. For more information on the differences between these two types of shell, see here.
I suggest you also read this excellent Q&A on Unix & Linux:
What is the exact difference between a 'terminal', a 'shell', a 'tty' and a 'console'?.
