20
I would like to open the terminal from the login screen. In previous Ubuntu releases I just used Ctrl+Alt+F1. However, when I press Ctrl+Alt+F1 in 18.04, nothing happens, the login screen just stays as it is. All other combinations with F-keys (F2 to F12) also have no effect whatsoever.
What key shortcut do I have to press to open the terminal from the login screen?
Ethunxxx
  • 516
7 Answers7
A new default configuration introduced to systemd around this time no longer allocates a graphical VT at a fixed tty7. Instead, tty1 is allocated to the display manager (gdm in Ubuntu Desktop), and new graphical consoles are allocated on other VTs when a user logins.
Right after boot when the graphical login screen shows up, the status of VTs may look like this:
tty1: gdm
tty2: (unallocated)
tty3: (unallocated)
tty4: (unallocated)
tty5: (unallocated)
tty6: (unallocated)
Once you log in, the new session would not appear at tty1 but at tty2:
tty1: gdm
tty2: gnome-shell
tty3: (unallocated)
tty4: (unallocated)
tty5: (unallocated)
tty6: (unallocated)
You can still pull up text mode sessions by switching to an unallocated VT in the tty1-tty6 range, which would automatically start agetty (and in turn text mode login) on that VT. The shortcut is CtrlAltFx from gdm, or simply AltFx from a text console, where x is a number key from 1 to 6.
If you have ever started a text session on tty2 before logging in from gdm, however, the graphical session will start on tty3, since tty2 is already used for text console.
tty1: gdm
tty2: text console
tty3: gnome-shell
tty4: (unallocated)
tty5: (unallocated)
tty6: (unallocated)
mcendu
  • 313
I had the same problem with ubuntu 16.04 on fresh install. Later everything started working. Try following:
sudo apt update
sudo apt upgrade
Run 'Software and Updates' and reboot
I knew answer is useless after so late but may help others
ROHIT
  • 59
chvt [n]
Source: http://manpages.ubuntu.com/manpages/trusty/man1/chvt.1.html
And while in a tty, shift + {left,right} arrow key to change screens.
This can also be an issue with your login manager preventing the process. For example, some Ubuntu based distributions use SDDM as the default manager and there is a bug that can prevent changing ttys. A solution would be to disable your login manager and either starting Xorg with startx (with the appropriate commands in ~/.xinitrc) or systemctl start your-login-manager.
# systemctl disable sddm
# shutdown -hr now
login:
password:
$ startx
    or
$ sudo systemctl start sddm
I'm not sure if this fulfills your desired answer but at least it enables accessing the terminal as this answer is valid for the time being ubuntu release.
The trick is to access a virtual terminal. Pressing Ctrl+Alt+F3 (again, refer to ubuntu docs for release-specific commands) spawns a tty session which is similar to opening terminal, moreover, the keybinding opens entirely new parallel session (non-graphical user interface). If you are the owner (superuser), you have full access to all running sessions; this becomes especially helpful in emergency cases. As you can switch back to your first session using Ctrl+Alt+F2 or Ctrl+Alt+F7 as referenced here
Enable Fn Lock by pressing Fn+Esc. Then try again.
-1
You can by pressing the combination button
Ctrl + alt + T
Call the terminal
Mehdi
  • 33
-1
You can press Ctrl+Alt+F4 to access tty screen. To exit it, you can press F1.
NotTheDr01ds
  • 22,082
