I have dell n5010
my system hang when I try to change brightness of the display and this happen only when my system on battery
please help how to solve this problem
I have dell n5010
The Dell Inspiron N5010 (and other Dell laptops eg. Dell Studio 1558, Inspiron 1464, Inspiron 1564, Inspiron M5010) has a bug in the firmware that causes it to hang in the backlight code under certain scenarios. This is kernel.org bug #57571 - Dell Inspiron N5010: freeze on adjusting brightness unless acpi_backlight=vendor is specified on boot and Launchpad bug #1007765 - brightness adjusting crashes system. There are two workarounds that may help:
Create the file /usr/share/X11/xorg.conf.d/20-intel.conf with contents:
Section "Device"
Identifier "card0"
Driver "intel"
Option "Backlight" "intel_backlight"
BusID "PCI:0:2:0"
EndSection
Log out and log back in again then test.
Add acpi_backlight=vendor to the boot parameters (some users report that this does not work for them)
For people that stumbled upon this years later (like me). Neither of these approaches worked for me. Probably because I have an AMD/ATI graphics card which is using the radeon_bl0 interface.
What fixed it for me was adding
echo 0 >/proc/sys/kernel/nmi_watchdog
to
/etc/rc.local
A longer explanation to this workaround can be found here Comment 96 for bug 1007765
