I am using the Syba USB soundcard for live audio from other audio sources like bluetooth or logitech mic. It's working perfectly, I am able to hear the live audio of bluetooth and logitech from the USB soundcard.
But the audio coming into the soundcard is not clear there is too much noise with the audio.
The USB soundcard has two port one for speaker and another for mic. When I hear the audio without plugin the headphone into speaker only plugin the headphne to mic then the noise is not coming.
But if I plugin the headphone in speaker port the noise coming is startrd.
Can I remove or control the noise coming into the soundcard.?
I am Using the following ffmpeg command for recording:
ffmpeg -loglevel warning -y -f v4l2 -s 544x288 -i /dev/video0 -vstats -vstats_file '/home/video-output//2014-05-13T07-18-37/left_cam-stats' -f pulse -name 'Unknown source 0' -i alsa_input.pci-0000_00_1b.0.analog-stereo -filter lowpass -f pulse -name 'left_mic 0' -i alsa_input.usb-046d_0823_D81A0330-00-U0x46d0x823_1.analog-stereo  -f pulse -name 'right_mic 1' -i alsa_input.usb-046d_0823_4B709030-00-U0x46d0x823.analog-stereo  -f pulse -name 'default 0' -i default  -f mpegts -crf 20 -r 24 -pix_fmt yuv420p -vcodec libx264 -vprofile baseline -t 02:00:00 -map 0:0 -map 1:0 -map 2:0 -map 3:0 -map 4:0 /home/left_cam.mp4
Prakash H
  • 2,631
