I'm using Ubuntu 14.04 x64 Desktop as OS. Trying to prepare a slideshow, when adding .eps image drawings to a slide there is no problem at all. But when i hit F5 to start slide show, slide that includes .eps image does not shown in output. Nothing just an empty screen appears. Althoug i have an external monitor, current slide does not shows .eps imported image but next slide area shows it.
Also tried to with unchecking Tools > Options > LibreOffice > View > "Use hardware acceleration".
Nothing changed.
Here is a screen shot of my outputs. On the right is presentation output, on the left is presentation helper screen.
http://oi57.tinypic.com/2rp2qa0.jpg
Both Slides included .eps image
akikara
  • 807
If you have Imagemagick installed try to convert the eps file in another format ( e.g. png).
If the problem is related to internal command of the eps file you should overcome it.
If you need high definition try
Change value for density in 150 300 600, or size (instead of 1024x1024) as needed
Hastur
  • 4,160
  • 32
  • 42
I had the same problem. Seems to be a problem with the (actual) version of LibreOffice in Ubuntu 14.04. I solved it updating LibreOffice to Versión: 4.3.0.4 using the code:
sudo add-apt-repository ppa:libreoffice/ppa
sudo apt-get update
sudo apt-get install libreoffice libreoffice-kde
according to this.
Luis
