I'm trying to make a working install of Ubuntu 14.04 on a Toshiba Satellite U200. Ubuntu is running pretty well, except there is absolutely no audio.
I have already followed all the advice in the Sound troubleshooting page, and the results were:
- I checked the audio settings tons of times: it is not muted, and the volume is at 100%. I can see the indicator on the panel and it seems active and not muted.
The sink is listed if I use
pacmdand thelist-sinkscommand. However the output is the following:$ pacmd Welcome to PulseAudio! Use "help" for usage information. >>> list-sinks 1 sink(s) available. * index: 0 name: <alsa_output.pci-0000_00_1b.0.analog-stereo> driver: <module-alsa-card.c> flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY state: SUSPENDED suspend cause: IDLE priority: 9959 volume: 0: 153% 1: 153% 0: 11,00 dB 1: 11,00 dB balance 0,00 base volume: 89% -3,00 dB volume steps: 65537 muted: no current latency: 0,00 ms max request: 0 KiB max rewind: 0 KiB [...] used by: 0 linked by: 0 configured latency: 0,00 ms; range is 0,50 .. 341,33 ms card: 0 <alsa_card.pci-0000_00_1b.0> module: 5 properties: [...] alsa.name = "AD1981 Analog" alsa.id = "AD1981 Analog" [...] alsa.long_card_name = "HDA Intel at 0x44080000 irq 43" alsa.driver_name = "snd_hda_intel" device.bus_path = "pci-0000:00:1b.0" sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0" device.bus = "pci" device.vendor.id = "8086" device.vendor.name = "Intel Corporation" device.product.id = "27d8" device.product.name = "NM10/ICH7 Family High Definition Audio Controller" [...] module-udev-detect.discovered = "1" device.icon_name = "audio-card-pci" ports: analog-output-speaker: Altoparlanti (priority 10000, latency offset 0 usec, available: unknown) properties: device.icon_name = "audio-speakers" analog-output-headphones: Cuffie analogiche (priority 9000, latency offset 0 usec, available: no) properties: device.icon_name = "audio-headphones" active port: <analog-output-speaker>I don't really like the
state: SUSPENDED, nor theused by: 0,linked by: 0and, at the end,available: unknown, however I'm not really sure what all this output means.When playing the test sounds I don't hear anything, even when using
sudo. The user wasn't in theaudiogroup, I have added the user to the group and nothing changed.- I tried to log in the guest session, but the audio doesn't work either.
- The sound card is recognize by Ubuntu and
aplay -ldoes show it. find /lib/modules/uname -r| grep snddoes find tons of modules, so the drivers seem to be there.Output of
lspci:$ lspci -v | grep -A7 -i "audio" 00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 02) Subsystem: Toshiba America Info Systems Device 0001 Flags: bus master, fast devsel, latency 0, IRQ 43 Memory at 44080000 (64-bit, non-prefetchable) [size=16K] Capabilities: <access denied> Kernel driver in use: snd_hda_intel $ sudo lspci -v | grep -A7 -i "audio" 00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 02) Subsystem: Toshiba America Info Systems Device 0001 Flags: bus master, fast devsel, latency 0, IRQ 43 Memory at 44080000 (64-bit, non-prefetchable) [size=16K] Capabilities: [50] Power Management version 2 Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+ Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00 Capabilities: [100] Virtual ChannelI don't understand whether the sound card is supported. I can see
ICH7in the Intel list, but I cannot findNM10/ICH7. Also it seems likeICH7devices use thesnd-intel8x0driver, which I have:$ find /lib/modules/`uname -r` | grep snd-intel8x0 /lib/modules/3.13.0-24-generic/kernel/sound/pci/snd-intel8x0.ko /lib/modules/3.13.0-24-generic/kernel/sound/pci/snd-intel8x0m.ko
Does somebody know how to fix this issue?
On this page it is me tioned that on some toshiba laptops not muting headphones may sometimes automatically mute the master volume. I have tried a lot of combinations of mute/unmute the various channels but nothing worked.
Later on the same page suggest doing:
$ sudo iecset audio on
And I get the following response:
control "IEC958 Playback Default" (index -1) not found
I don't whether this might be useful, but the internal microphone works perfectly. I can record sound but I'm unable to play it.
I just noticed that when doing alsa force-reload, it says that it fails to unload some modules:
$ sudo alsa force-reload
Unloading ALSA sound driver modules: snd-seq-midi snd-seq-midi-event snd-seq snd-rawmidi snd-seq-device snd-hda-codec-si3054 snd-hda-codec-analog snd-hda-intel snd-hda-codec snd-hwdep snd-pcm snd-page-alloc snd-timer (failed: modules still loaded: snd-hda-codec-si3054 snd-hda-codec-analog snd-hda-intel snd-hda-codec snd-hwdep snd-pcm snd-page-alloc snd-timer).
Loading ALSA sound driver modules: snd-seq-midi snd-seq-midi-event snd-seq snd-rawmidi snd-seq-device snd-hda-codec-si3054 snd-hda-codec-analog snd-hda-intel snd-hda-codec snd-hwdep snd-pcm snd-page-alloc snd-timer.
$ echo $?
