I did some changes on my wi-fi connection to give ip manual and somethings else I do not remember what exactly i did and now Wi-Fi connection is not enable on the menu bar I set my connection again to DHCP but also I do not have any wireless access point. In that bar beside the time on the above there is **Enable Wi-Fi **which is inactive
Update:I did jgrocha's steps. after that I saw
phy0: wireless LAN
Soft blocked: no
Hard blocked: yes
I follow link and my problem solved
You can use
sudo rfkill list all
on the command line to see which devices are enabled or disabled. To enable the device, you can try something like
sudo rfkill unblock wifi
or
sudo rfkill unblock all
Afterwards, the enable wifi option should be enabled on the applet.
estibordo
  • 1,419
