Is there an equivalent of APTonCD for Ubuntu Server (12.04) edition ?
If not, can I use a local repository cread by APTonCD (using a Desktop edition) and use it from Ubuntu Server 12.04 edition ? If yes, how ?
I will expand this if you explain exactly what you need to do but to answer the question you asked, yes it is possible to use an image created by aptoncd with Ubuntu Server.
If you have access to a GUI Ubuntu Create the image file using the instructions here on your Desktop install.
A. If your server has a CD drive
  1. Burn the image to a CD (you can do this using aptoncd) and put the CD in your server's drive.
  2. Open a terminal and run
    sudo apt-cdrom add
  3. Update your sources list
    sudo apt-get update
B. If your server has no CD drive
If you don't have a CD drive on your server, you will need to mount the image file and then add that.
  1. Copy the image file (something like aptoncd-20140505-CD1.iso) to your server.
  2. Mount the image somewhere
    sudo mkdir /media/foo
    sudo mount -o loop /path/to/aptoncd-20140505-CD1.iso /media/foo
  3. Run apt-cdrom again but telling it not to attempt to detect the CD automatically, nor to mount it (-m) and specifying the mount point (-d) as /media/foo:
    sudo apt-cdrom --no-auto-detect -md /media/foo add
  4. Update your sources list
    sudo apt-get update
terdon
  • 104,119
