so far:
sudo mount -t ntfs -o rw,auto,user,fmask=0000,dmask=0000 /dev/sdc1 /media/BB
works fine, every permission is set to read and write, now all i need is for the owner not to be "root"
what can i do to mount the ntfs with me as owner?
is there any modification i can to the above command?
like user="me" ? or what? ive searched far and wide and cant find so much things
mount help is not verry helpful
mount --help
Usage: mount -V                 : print version
       mount -h                 : print this help
       mount                    : list mounted filesystems
       mount -l                 : idem, including volume labels
So far the informational part. Next the mounting.
The command is `mount [-t fstype] something somewhere'.
Details found in /etc/fstab may be omitted.
       mount -a [-t|-O] ...     : mount all stuff from /etc/fstab
       mount device             : mount device at the known place
       mount directory          : mount known device here
       mount -t type dev dir    : ordinary mount command
Note that one does not really mount a device, one mounts
a filesystem (of the given type) found on the device.
One can also mount an already visible directory tree elsewhere:
   mount --bind olddir newdir
or move a subtree:
       mount --move olddir newdir
One can change the type of mount containing the directory dir:
       mount --make-shared dir
       mount --make-slave dir
       mount --make-private dir
       mount --make-unbindable dir
One can change the type of all the mounts in a mount subtree
       mount --make-rshared dir
       mount --make-rslave dir
       mount --make-rprivate dir
       mount --make-runbindable dir
A device can be given by name, say /dev/hda1 or /dev/cdrom,
or by label, using  -L label  or by uuid, using  -U uuid .
Other options: [-nfFrsvw] [-o options] [-p passwdfd].
For many more details, say  man 8 mount .
Chuck R
  • 5,038
Then Enok
  • 855
A. sudo mkdir /media/ntfsPartition - this will create a folder in your media directory, you can add any name you want;
B. sudo blkid - find the UUID of the ntfs partition you want to mount;
C. sudo gedit /etc/fstab - add a new line with your ntfs partition you wish to mount by writing a new line on bottom (ex: should look like this)
#ntfs_partition
UUID=xxxxxxxxxxxxxxxx /media/ntfsPartition ntfs defauls,uid=1000,gid=1000,noatime 0 0
(before point D, check if the uid and gid is 1000 by typing in terminal id)
D. Save the file;
E. sudo mount -a - this will mount your ntfs partition;
F. Done
*Testing and using my ntfs partitions in this way on Ubuntu 14.04.
For older versions, check this - How to automount NTFS partitions?
Dave
  • 1,047
