10
I have a Windows 7 with VirtualBox. I did install a fresh downloaded Ubuntu 14.04 (64bit). I did install the guest additions. I wanted to set the screen resolution to a higher value than 640x480. I did go over on/off (top right)--system settings--hardware--viewing devices.
I get only "eingebaute Anzeige" (German, Wnglish would probably be "builtin display") and only one screen resolution. I have found a howto for Ubuntu 9 and did try to edit/create an /etc/X11/xorg.conf. But this too didn't work.
user277068
  • 101
5 Answers5
14
Sometimes the packaged version of the Guest additions gives better results.
So I'd suggest to update the Guest additions with the VM package manager. So login first into your VM and open a Terminal to type:
sudo apt-get install virtualbox-guest-dkms virtualbox-guest-utils virtualbox-guest-x11
Finally restart the Ubuntu VM to complete the installation.
You should get access to higher resolutions now.
Original screen size was 640 x 480.
In Oracle VM VirtualBox Manager go to:
File --> Preferences
Click on Display
On the Maximum Guest Screen Size dropdown change Automatic to None
Click on OK
On my Dell Precision M6500A laptop system running Windows 7 after restarting Oracle VM VirtualBox Manager and then starting the Ubuntu 14.0.4 VM my default screen settings (1024 x 768) were taken with (800 x 600) as a second choice
I had the same problem. What worked for me was upgrading VirtualBox to the latest version, and installing from its built-in Guest Additions CD.
sashoalm
  • 5,241
You should install the virtual-box guest additions by entering the devices menu and select "install Virtual Box Guest Additions". Then you go to your running session of your virtualized OS and open a terminal. Go to your media path : /media/(user-name)/vbox.... (I don't remember the name of the CD) then in the terminal run the following command
apt-get install gcc (if you don't have it yet)
./VBoxLinuxAdditions.sh (the name of your installation file (it ends by .sh)
if the previous command don't work execute this one :
sh VBoxLinuxAdditions.sh
Let this run and reboot your VBox machine. It should have the correct screen resolution now.
Be sure to have an up to date version of your Virtual Box Software.
jeremielc
  • 615
virtualbox4.2.12 is unusable, please upgrade your virtualbox first. I have tried every method over ubuntu official forum, and the methods doesn't work, after I upgrade my virtualbox to 5.X, and it works.
zzj
