22
So I updated to Ubuntu 14.04 and found that the primusrun command no longer works, so ditched bumblebee in favour of nvidia-prime. This lets you switch video card from nvidia-settings rather than running through the command line (I prefer the old method, but want the primus performance).
The problem is that after switching to Intel from nvidia-settings, I can no longer open it up again to switch back to the nvidia card. When I open nvidia-settings I get a segmentation fault (according to the terminal).
Is there any way to open nvidia-settings switch back? I would like the ability to be able to switch between the two since having the nvidia card on all the time kills my battery and heats up the laptop a lot.
This is a bug (LP #1214508).
You can switch using:
sudo prime-select intel
sudo prime-select nvidia
Also, Bumblebee is still supported so you can install it if you prefer. You'll have to remove nvidia-prime then as you can't use both.
