yesterday I bought a laptop which contains both a Nvidia 940mx graphics card and Intel Integrated Graphics. I have found that it uses the Intel integrated graphics by default, but I wish for it to use the Nvidia card instead.
I have already tried switching while using Arch Linux and have switched to Ubuntu in hopes that it will work here, as when I made an attempt on Arch Linux, it resulted in the X Server being entirely unable to start, reporting that it is unable to locate the display, or something along those lines. Because I have already had this issue with switching, I am hesitant to try again without first ensuring that everything will work correctly.
There seem to be several conflicting (and outdated) guides for switching to the nvidia card. Using vga_switcheroo did not work, as the /sys/kernel/debug/vgaswitcheroo/switch did not even exist. Any existing questions on stack exchange which describe utilizing the nvidia card are either outdated, inconsistent with all the others, or are not consistent with my situation.
Some Hardware Information:
$ lspci -nnk | grep -i vga -A3 | grep 'in use'
Kernel driver in use: i915
$ lshw -short | grep display
/0/100/2 display Intel Corporation
/0/100/1c/0 display NVIDIA Corporation
$ lshw | grep -A10 "VGA\|3D"
description: VGA compatible controller
product: Intel Corporation
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 02
width: 64 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:131 memory:b2000000-b2ffffff memory:c0000000-cfffffff ioport:5000(size=64) memory:c0000-dffff
description: 3D controller
product: NVIDIA Corporation
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a2
width: 64 bits
clock: 33MHz
capabilities: cap_list
configuration: latency=0
resources: memory:b3000000-b3ffffff memory:a0000000-afffffff memory:b0000000-b1ffffff ioport:4000(size=128) memory:b4000000-b407ffff
$ lspci -nnk | grep -i "VGA\|3D" -A3
00:02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:5916] (rev 02)
Subsystem: Acer Incorporated [ALI] Device [1025:111a]
Kernel modules: i915
01:00.0 3D controller [0302]: NVIDIA Corporation Device [10de:179c] (rev a2)
Kernel modules: nvidiafb, nouveau
03:00.0 Network controller [0280]: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter [168c:0042] (rev 31)
$ sudo ubuntu-drivers devices
== cpu-microcode.py ==
driver : intel-microcode - distro non-free
== /sys/devices/pci0000:00/0000:00:1c.0/0000:01:00.0 ==
vendor : NVIDIA Corporation
modalias : pci:v000010DEd0000179Csv00001025sd0000111Abc03sc02i00
driver : xserver-xorg-video-nouveau - distro free builtin
driver : nvidia-367 - distro non-free recommended
$ arch
x86_64
Given this information, what is the safest way for me to switch from the intel device to the nvidia graphics card without a risk of breaking the X server? This system is running Ubuntu 16.10 Yakkety.
