I'm new to Ubuntu and have reinstalled 11.04 at least 10 times already.
Each time I reconfigure all my settings and end up breaking something.
It is really annoying and would be much easier if I could save everything onto a cd and reinstall from the cd so my settings would be restored like in Windows.
Is there a way to do that? Thank you in advance.
Zanna
  • 72,312
Alex
  • 61
The home directory contains per-user settings, /etc contains system-wide settings and /var/lib/dpkg contains package state information. With that information, you can restore your system fully on a new installation.
A backup of your settings is the key solution: Comparison of backup tools
To make a disk clone (disk image), see How to make a disk image and restore from it later?
If you want to experiment, consider using a Virtual Machine with VirtualBox. Using VirtualBox, you can take snapshots of the system (even if running) which can be restored later.
Lekensteyn
  • 178,446
Ubuntu tweak saved my "proverbial behind" several times as it can save desktop, applications and system settings.
Download it and save your settings step by step as your system evolves and restore if you break it. Use desktop recovery and backup to save it restore to go back to specific point in time and reset to get back to the normal settings.
Mateo
  • 8,152
dago
  • 2,384
Ubuntu retains the 'default' configuration of each program. So if you break something you can restore just that application by using:
dpkg-reconfigure [package name]
Check this out - http://www.psychocats.net/ubuntu/backup - rsync and remastersys. Rysnc can be used for any type of file. Remastersys is for making something like a clone of ur current desktop.
