I cannot install Wine on Ubuntu 14.04. When I try to install it on the Ubuntu Software Center I always get a message that says I have unmet dependencies. I tried installing Wine through the terminal and I get this:
Reading package lists... Done
Building dependency tree
 wine : Depends: wine1.6 but it is not going to be installed
saiarcot895
  • 10,917
aappletart
  • 71
sudo add-apt-repository ppa:ubuntu-wine/ppa
sudo apt-get update
sudo apt-get install wine1.7
Source
Qasim
  • 22,162
Open your terminal by press Ctrl + Alt + T and type this following on terminal
sudo apt-get update
sudo apt-get install wine1.7 winetricks
That's it
Liso
  • 15,677
sudo apt-get update
sudo apt-get upgrade
and then just try installing again.
Bary12
  • 183
