I did a fresh install of Xubuntu 14.04. Executables like Opera Mobile Emulator no longer work. I have already tried the solutions from:
No such file or directory for existing executable
How to run 32-bit app in Ubuntu 64-bit?
Though the error message is not showing up, Opera emulator does not fire up. Any help would be great.
Update: The commands already tried are:
dpkg --add-architecture i386
apt-get install ia32-libs - doesn't work, deprecated
apt-get install libsdl1.2debian:i386
apt-get install libstdc++6:i386 libgcc1:i386 zlib1g:i386 libncurses5:i386
apt-get install libc6-i386 lib32stdc++6 lib32gcc1 lib32ncurses5 lib32z1
The same rings true. You need to install what it needs. You can usually find out what it needs by running it in a command line and interpreting the errors and just installing the :i386 versions of those packages.
In this case...
sudo apt-get install libqtgui4:i386 libgl1-mesa-glx:i386
... Should be enough.
Oli
  • 299,380
