what is the usage of apt-get -f install . when I run sudo apt-get update I got some errors at the end It says try apt-get -f install. What is this command? the last part of my error is :
going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
guntbert
  • 13,475
See the manpage:
-f, --fix-broken
   Fix; attempt to correct a system with broken dependencies in place.
   This option, when used with install/remove, can omit any packages
   to permit APT to deduce a likely solution. If packages are
   specified, these have to completely correct the problem. The option
   is sometimes necessary when running APT for the first time; APT
   itself does not allow broken package dependencies to exist on a
   system. It is possible that a system's dependency structure can be
   so corrupt as to require manual intervention (which usually means
   using dselect(1) or dpkg --remove to eliminate some of the
   offending packages). Use of this option together with -m may
   produce an error in some situations. Configuration Item:
   APT::Get::Fix-Broken.
It's one of the first solutions when trying to solve umet dependencies. (See this question: How do I resolve unmet dependencies after adding a PPA?)
chaos
  • 28,186
