I wanted to get a look at MySQL 5.6 on Ubuntu 14.04 just out of curiosity. And based on this article it certainly looked like installation should be simple and straightforward. So I fired up an AWS EC2 micro server running Ubuntu 14.04 (64-bit), logged into my pristine instance (via PuTTY), and issued the following commands:
$ sudo apt-get update
$ sudo apt-get build-dep mysql-server-5.6
$ sudo apt-get install mysql-server-5.6
(The first two commands were desperation moves, since simply running apt-get install alone had previously not worked. But even with all three commands, the install step still did not work.)
At the point where I expected, based on the article referenced above, to see this output from the final command:
mysql start/running, process 2355
Setting up libhtml-template-perl (2.95-1) ...
Setting up mysql-common-5.6 (5.6.16-1~exp1) ...
Processing triggers for libc-bin (2.19-0ubuntu6) ...
Processing triggers for ureadahead (0.100.0-16) ...
I got this instead:
start: Job failed to start
invoke-rc.d: initscript mysql, action "start" failed.
dpkg: error processing package mysql-server-5.6 (--configure):
subprocess installed post-installation script returned error exit status 1
mysql-server-5.6
Can anyone see what went wrong?
