After upgrading to Ubuntu 14.04 a strange error occurred: keystroke on c has no effect, whereas a longer stroke gives a lot of c's (as expected).
The error is reproducible, but appears in Unity only, not in Gnome 3.10 which is installed as well. Key c still works well at the login prompt. Changing the keyboard layout (from German to English) has no effect. So it shouldn't be a hardware error, nor an error of the keyboard layout. But what else could it be? As far as I mentioned, there are no other keys affected.
Does anyone have a clue?
karel
  • 122,292
  • 133
  • 301
  • 332
kroeja
After checking user275435-comment, I found a solution: I looked through all shortcuts and disabled (press backspace) all with a hexcode, e.g. 0xa1. Now the c-key works again.
Mi-Ro
Finally, I found a solution: As only Unity was affected, I came across this solution: change dash lens hotkey
But since lenses are scopes now, I edited file /usr/share/unity/scopes/photos.scope instead (as root): Change
Shortcut=c
to
Shortcut=
and for security, add
ShowEntry=false
Then restart Unity and log out or restart computer.
Additionally I removed all the lenses/scopes I never use: remove unity lenses
Do the logout/restart thing again and, voilĂ : Key c is working again!
kroeja
I had the same problem after upgrade to 14.04 on the unity desktop, the problem was the program touchpad-indicator. This has a shortcuts created under "All Settings - Keyboard - did own shortcuts"
