314
I can connect to another Ubuntu machine in my LAN via SSH. On both of then PC's I installed openssh-server but from another Ubuntu computer I can not connect to my PC via SSH and I got this error:
Host key verification failed...
techraf
  • 3,316
Navid
  • 3,353
20 Answers20
336
"Host key verification failed" means that the host key of the remote host was changed.
SSH stores the host keys of the remote hosts in ~/.ssh/known_hosts. You can either edit that text file manually and remove the old key (you can see the line number in the error message), or use
ssh-keygen -R hostname
From man page:
-R hostname
Removes all keys belonging to hostname from a known_hosts file. This option is useful to delete hashed hosts .
(which I learned from the answer to Is it possible to remove a particular host key from SSH's known_hosts file?).
elmicha
  • 9,960
218
If you are running in certain remote/scripting situations where you lack interactive access to the prompt-to-add-hostkey, work around it like this:
$ ssh -o StrictHostKeyChecking=no user@something.example.com uptime
Warning: Permanently added 'something.example.com,10.11.12.13' (RSA) to the list of known hosts.
Alain
  • 1,074
MarkHu
  • 6,218
23
Maybe you just need to enter "yes" when ssh confirm you want to continue connecting.
Like below:
The authenticity of host 'xxx' can't be established.
ECDSA key fingerprint is yyy.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added 'xxx' (ECDSA) to the list of known hosts.
Enter passphrase for key '/Users/ysy/.ssh/id_rsa':
Then enter your password.
Please pay attention to "Are you sure you want to continue connecting (yes/no)? yes". You must enter "yes", not "enter".
JChen___
  • 331
17
you have to put the rsa key of the target host into the source host /home/user/.ssh/known_hosts by running this on the target
ssh-keyscan -t rsa @targethost
16
Also sometimes there is situation when you are working on serial console, then checking above command in verbose mode -v will show you /dev/tty does not exist, while it does.
ssh -v user@hostname
In above case just remove /dev/tty and create a symlink of /dev/ttyS0 to /dev/tty.
rm /dev/tty
ln -s /dev/ttyS0 /dev/tty
As an alternative, add id_rsa.pub to the remote location, so password is not prompted and you get login access.
kiri
  • 28,986
Peeyush
  • 287
12
In my case, this was caused by a udev problem - there was no /dev/tty device node. The solution for me was just:
sudo mknod -m 666 /dev/tty c 5 0
muru
  • 207,228
Mark
  • 121
On terminal:
ssh -o StrictHostKeyChecking=no -i YourPublicKey.pem user@example.com uptime
The following message, or similar, will appear:
Warning: Permanently added 'example.com, XX.XXX.XXX.XX' (ECDSA) to the list of known hosts.
 00:47:37 up 3 min,  0 users,  load average: 0.00, 0.00, 0.00
Then, connect to your EC2 as normal:
ssh -i YourPublickey.pem user@example.com
bUff23
  • 117
Vitor Abella
  • 8,015
  • 16
  • 63
  • 115
This is an old thread and I just ran across this answer, I will just add what I did to solve this.
ssh-keygen -f "/home/USER/.ssh/known_hosts" -R HOSTNAME
I just looked at the error message that it threw at me and it said to run that command in order to remove it from the list of hosts. After that I did the following:
ssh-copy-id HOSTNAME
Than I followed the prompts from there until I was able to ssh into the server.
Hatem Jaber
  • 326
  • 13
Other than strictly disable host key checking, you can also connect by typing:
ssh -o LogLevel=quiet -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no <username@target_machine_ip_or_domain_name>
Farshid
  • 289
Well, it simply because the second ubuntu requires connection by key and not password.
I suggest you use sudo dpkg-reconfigure openssh-server on your pc, and then it should work properly. It will reset the configuration for openssh and should come back to a default password authentication.
Second possibility is that there's already a key for your other ubuntu in you PC, and that it changed thus being not recognized anymore. In this case, you'll have to edit the file .ssh/authorized_keys to remove the problematic line identifying your ubuntu.
MP0
  • 141
You should change your key in this way: From your given error find which host-key changed for example: Offending ECDSA key in /Users/user-name/.ssh/known_hosts:5 said 5th key changed, so do this:
sed -i '5d' ~/.ssh/known_hosts
Notice: you must be root or have privilege for sudo.
Its means your remote host key was changed (May be host password change),
Your terminal suggested to execute this command as root user
$ ssh-keygen -f "/root/.ssh/known_hosts" -R [www.website.net]:4231
You have to remove that host name from hosts list on your pc/server. Copy that suggested command and execute as a root user.
$ sudo su                                                            // Login as a root user
$ ssh-keygen -f "/root/.ssh/known_hosts" -R [www.website.net]:4231   // Terminal suggested command execute here
Host [www.website.net]:4231 found: line 16 type ECDSA
/root/.ssh/known_hosts updated.
Original contents retained as /root/.ssh/known_hosts.old
$ exit                                                               // Exist from root user
$ sudo ssh root@www.website.net -p 4231                              // Try again
Hope this works.
If you add the -v option to ssh (possibly more than once) it will print all sorts of stuff which may help in identifying the problem. In my case it complained about /dev/tty permissions, and chmod 666 /dev/tty fixed the problem.
Just do "sudo vi /var/root/.ssh/known_hosts" and remove the line, that holds a key for a host you're trying to connect to and reconnect again.
I don't know about your particular situation, but most probably this error came along with a message like this:
my_mac:~ oivanche$ sudo ssh pi@192.168.0.45
@    WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED!     @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the ECDSA key sent by the remote host is
SHA256:sx1Z4xyGY9venBP6dIHAoBj0VhDOo7TUVCE2xWXpzQk.
Please contact your system administrator.
Add correct host key in /var/root/.ssh/known_hosts to get rid of this message.
Offending ECDSA key in /var/root/.ssh/known_hosts:74
ECDSA host key for 192.168.0.45 has changed and you have requested strict checking.
If you'll read the log more carefully you'll see that the key you've got from a host is conflicting with a key you already have - in this case it's on line 74 of known_hosts file (Offending ECDSA key in /var/root/.ssh/known_hosts:74). Remove the line from the known_hosts, save changes and reconnect.
user68186
  • 37,461
For most of the cases, the error msg returned by the Linux would have told you what to do. For instance in the earlier answer:
It says that the remote server host key has changed - therefore your previously stored local record DOES NOT MATCH any more. For security reasons the connection is not established.
The simplest solution would be just deleted the line mentioned (line 74) in your local pc in /var/root/.ssh/known_hosts by
sudo nano /var/root/.ssh/known_hosts
You would want to deleted the line mentioned ONLY. No easier way just use your keyboard cursor and backspace or delete keys.
Once deletion is done, save it by command Ctrl+o and quit the file by command Ctrl+x.
Now reconnect to your host via ssh, using something like this:
ssh -i /Users/ben/document/key.pem root@192.168.0.45
where /Users/ben/document/key.pem is your server's key pair you had set to use (can't find it anymore? go to the hosting site to regenerate one) and 192.168.0.45 is your remote server IP you are connecting to.
When prompted with something like are you sure you want to add the host key permanently to this machine? type yes. Then you have updated your local key for connecting to the remote server for good.
Hope this clarifies and helps.
seedme
  • 111
My solution comes from this blog post: Algorithm negotiation failed for SSH Secure Shell Client
You need to modify the file as follows:
sudo nano /etc/ssh/sshd_config
And then add the following:
# Ciphers
Ciphers aes128-cbc,aes192-cbc,aes256-cbc,blowfish-cbc,arcfour
KexAlgorithms diffie-hellman-group1-sha1
Basically you tried different solutions until you find one which can solve your problem. If the above solutions don't work, please try this one. If this one doesn't work as well, please try others.
wjandrea
  • 14,504
when this is on the screen: "Are you sure you want to continue connecting (yes/no)?" you need to enter yes, instead of pressing the enter or return key try this!
Find the .ssh folder for your user.
cd /home/<user>/.ssh
Eg : If the user is jenkins,
cd /home/jenkins/.ssh
Then open the known_hosts file.
vi known_hosts
Search your remote server IP address and delete that row.
save the file and connect!
pico ~/.ssh/known_hosts and delete all lines, after just reconnect and you will get a new key.
Mark Paskal
  • 2,890
H0nsu
chmod 666 /dev/tty
is yet another tty solution - sometimes, this device file has wrong permissions.
Alex
