I am trying to scp the files from machineB to machineA. I need to run the scp command from machineA to copy files from machineB to machineA.
The file that I need to copy from machineB is -
/bat/data/snapshot/5.data
And where I need to copy the file into machineA is -
/data01/primary
in which I have root access as well and /data01/primary has only root credentials. Below is the ls -lt on machineA
david@machineA:/$ ls -lt
drwxr-xr-x   3 root root  4096 Nov  7 17:43 data02
drwxr-xr-x   3 root root  4096 Nov  7 17:42 data01
drwxr-xr-x   4 root root  4096 Nov  7 17:26 opt
So I was trying the below scp command on machineA to copy the files -
scp david@machineB:/bat/data/snapshot/5.data root@machineA:/data01/primary
but I am always getting -
Host key verification failed.
I do have root access to machineA but not root access to machineB. And I can ping machineB from machineA as well. And both machines are in production domain as well.
SSH
  • 3,041
Problem with the ~/.ssh/known_hosts can cause this. You can either remove the file
rm -i ~/.ssh/known_hosts
or you could edit the file and remove the line containing machine B.
sourav c.
  • 46,120
