i upgraded to 14.04 and afterwards i got an issue with cpu usage when playing HD.
I checked the vainfo and this what i got back
ibva info: VA-API version 0.35.0
libva info: va_getDriverName() returns -1
libva error: va_getDriverName() failed with unknown libva error,driver_name=(null)
vaInitialize failed with error code -1 (unknown libva error),exit
I re install the driver sudo apt-get --reinstall install i965-va-driver but i steel got the same error.
Any thoghts
MIkCode
  • 31
A speculative answer given the brevity of the question.
A very recent thread in Arch Linux reported the same error.
Therefore two suggestions to try:
  1. Remove your xorg.conf file - I'm making the assumption you have one defined.
    sudo mv /etc/X11/xorg.conf /etc/X11/xorg.conf.backup
  2. reboot
If this doesnt work, you can revert using:
sudo mv /etc/X11/xorg.conf.backup /etc/X11/xorg.conf
Suggestion 2:
  1. Look at the contents of your xorg.conf file and change the AccelMethod value to "glamor"
    sudo nano /etc/X11/xorg.conf
fossfreedom
  • 174,526
