23
I recently upgraded from Ubuntu 12.04 to Ubuntu 14.04. After restarting I have WiFi connected and/or LAN connection with no internet access. I'm using Toshiba Satellite C855D.
$ sudo lshw -C network
  *-network
       description: Wireless interface
       product: RTL8188CE 802.11b/g/n WiFi Adapter
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: wlan0
       version: 01
       serial: c0:d9:62:8d:39:85
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=rtl8192ce driverversion=3.13.0-24-generic firmware=N/A ip=192.168.0.109 latency=0 link=yes multicast=yes wireless=IEEE 802.11bgn
       resources: irq:16 ioport:3000(size=256) memory:f0200000-f0203fff
  *-network
       description: Ethernet interface
       product: RTL8101E/RTL8102E PCI Express Fast Ethernet controller
       physical id: 0
       bus info: pci@0000:06:00.0
       logical name: eth0
       version: 05
       serial: 00:8c:fa:49:e0:4d
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl_nic/rtl8105e-1.fw latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       resources: irq:41 ioport:2000(size=256) memory:f0104000-f0104fff memory:f0100000-f0103fff
$ ifconfig -a
eth0      Link encap:Ethernet  HWaddr 00:8c:fa:49:e0:4d
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:727 errors:0 dropped:0 overruns:0 frame:0
          TX packets:727 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:56993 (56.9 KB)  TX bytes:56993 (56.9 KB)
wlan0     Link encap:Ethernet  HWaddr c0:d9:62:8d:39:85
          inet addr:192.168.0.109  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::c2d9:62ff:fe8d:3985/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:1934 errors:0 dropped:0 overruns:0 frame:0
          TX packets:61 errors:0 dropped:0 overruns:0 carrier:0
$ ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=47 time=47.2 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=47 time=44.8 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=47 time=43.6 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=47 time=156 ms
$ ping google.com
ping: unknown host google.com
$ nslookup google.com 8.8.8.8
Server:     8.8.8.8
Address:    8.8.8.8#53
Non-authoritative answer:
Address: 190.167.241.187
Address: 190.167.241.178
Address: 190.167.241.163
Address: 190.167.241.183
Address: 190.167.241.177
Address: 190.167.241.172
Address: 190.167.241.153
Address: 190.167.241.162
Address: 190.167.241.167
Address: 190.167.241.152
Address: 190.167.241.168
Address: 190.167.241.182
Address: 190.167.241.157
Address: 190.167.241.173
Address: 190.167.241.148
Address: 190.167.241.158
$ cat /etc/resolvconf/resolv.conf.d/head
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
#     DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 8.8.8.8
$ sudo service networking restart
stop: Job failed while stopping
start: Job is already running: networking
$ nm-tool
NetworkManager Tool
State: connected (global)
- Device: eth0 -----------------------------------------------------------------
  Type:              Wired
  Driver:            r8169
  State:             unavailable
  Default:           no
  HW Address:        00:8C:FA:49:E0:4D
  Capabilities:
    Carrier Detect:  yes
    Speed:           100 Mb/s
  Wired Properties
    Carrier:         off
- Device: wlan0  [Honey Nut Cheerios] ------------------------------------------
  Type:              802.11 WiFi
  Driver:            rtl8192ce
  State:             connected
  Default:           yes
  HW Address:        C0:D9:62:8D:39:85
  Capabilities:
    Speed:           18 Mb/s
  Wireless Properties
    WEP Encryption:  yes
    WPA Encryption:  yes
    WPA2 Encryption: yes
  Wireless Access Points (* = current AP)
    *Honey Nut Cheerios: Infra, 00:21:29:EF:11:2D, Freq 2437 MHz, Rate 54 Mb/s, Strength 78 WPA2
    Claro8AD:        Infra, 00:1A:2B:B0:69:CD, Freq 2462 MHz, Rate 54 Mb/s, Strength 27 WPA2
    CLAROB5F570:     Infra, 88:25:2C:B5:F5:70, Freq 2412 MHz, Rate 54 Mb/s, Strength 20 WEP
    WIND30:          Infra, 00:1F:FB:68:E3:6C, Freq 2427 MHz, Rate 54 Mb/s, Strength 37 WPA
    dd-wrt_vap:      Infra, 02:1C:10:34:41:15, Freq 2437 MHz, Rate 54 Mb/s, Strength 24 WPA
  IPv4 Settings:
    Address:         192.168.0.109
    Prefix:          24 (255.255.255.0)
    Gateway:         192.168.0.1
    DNS:             8.8.8.8
    DNS:             8.8.4.4
Zanna
  • 72,312
I had this same problem on my upgrade from 12.04 to 14.04. The way I fixed it was by complete removal and reinstall of the resolv config. See below
sudo apt-get remove --purge resolvconf && sudo apt-get install --reinstall resolvconf
It appears that your upgrade as my did not properly install your DNS resolver.
Nattgew
  • 2,139
user279062
  • 159
Your DNS servers are not set or not working properly.
A DNS server basically translates (resolves) a domain name (like google.com) to an IP address. Without an IP address you can't connect to any website. So if a domain name can't be resolved, you can't access any website.
You can use Google's DNS servers to solve this problem:
  1. Click on the WiFi icon in the top right of your screen
  2. Click on Edit connections...
  3. Under Wi-Fi, select your network's name
  4. Click on Edit...
  5. Click on IPv4 Settings
  6. Set Additional DNS Servers to 8.8.8.8, 8.8.4.4 (note the difference between the dot and the comma)
  7. Click on Save
Try to visit Google to verify that your connection's working.
This is the problem. Ubuntu now by default sets 127.0.0.1 as your nameserver, placing that in your resolv.conf.
You can add a header to include your perferred name server such as google's dns by using the resolvconf header feature.
Add your preferred nameserver to your header file:
nameserver 8.8.8.8
Be sure to place a linefeed at the end (press ENTER) after the line. Then restart your network and you should be all set.
This will place your preferred nameserver at the top of the default settings when your network starts.
You can restart your network by rebooting your computer or issue this cli:
L. D. James
  • 25,444
Recreate /etc/resolv.conf by running the following in Terminal (Ctrl+Alt+T) and it should fix the issue with ping:
sudo dpkg-reconfigure resolvconf
or
sudo ln -sf /run/resolvconf/resolv.conf /etc/resolv.conf
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Shayan
  • 1,621
