I installed Ubuntu 13.10 to my desktop which has 1 GB main memory and AMD 64 bits CPU. It happens that the system freeze, applications not response sometimes and crashes a few times.
I just learn that 1 GB is minimum requirement for Ubuntu 64 bits. I just wonder if it is memory not enough that I better to increase to 2 GB to improve performance.
Your help and information is great appreciated,
Regards,
Inung
landroni
  • 6,011
  1. The minimum for 64bit Ubuntu is 768 MB of RAM memory.
  2. Try increasing your swap memory.
  3. I think you can use 32bit version, it would be better.
And one more tip: use Ubuntu 12.04 LTS.
aastefanov
  • 1,399
If you have 1GB of RAM and 64-bit architecture, then I would suggest two things:
  1. Use a 32-bit version of Ubuntu
  2. Use either Xubuntu or Lubuntu. Whatever you do, with such hardware configuration stay away from the resource-hungry Unity.
And lastly, add a sufficient dose of swap. Anything above 2GB should work fine.
See also:
landroni
  • 6,011
Couple points:
  • increase swap
  • use openbox or blackbox destktop environments as super-light-weight alternatives (my ram usage with it right now is around 700 MB , no flash running)
  • limit startup scripts, processes, etc.
  • Use a usb as RAM: refer here or here
