29
I was trying to create an WiFi hotspot for my android device. I used ap-hotspot to do so.
I configured the ap-hotspot using
sudo ap-hotspot configure
Then I started ap-hotspot using
sudo ap-hotspot start
Then it shows this
Starting Wireless Hotspot...
And then nothing happens, no further message is displayed, hotspot is not created.
What is Wrong? How to fix it?
Braiam
  • 69,112
rajan
  • 879
ap-hotspot uses hostapd to create wireless network
I had problems creating hotspot using hostapd in Ubuntu 14.04 mainly because new version of hostapd in 14.04 default repository is buggy.
You can solve this problem by downgrading hostapd in Ubuntu 14.04 LTS to a previous version
Uninstall buggy hostapd using apt-get:
sudo apt-get remove hostapd
Then install non-buggy version of hostapd:
  • 64 - bit:
    cd /tmp
    wget http://old-releases.ubuntu.com/ubuntu/pool/universe/w/wpa/hostapd_1.0-3ubuntu2.1_amd64.deb
    sudo dpkg -i hostapd*.deb
    sudo apt-mark hold hostapd
  • 32 - bit:
    cd /tmp
    wget http://old-releases.ubuntu.com/ubuntu/pool/universe/w/wpa/hostapd_1.0-3ubuntu2.1_i386.deb
"sudo apt-mark hold hostapd" will prevent hostapd to upgrade to the buggy version.
Then try running ap-hotspot again, I think it should work. It worked for me like a charm.
Back.Slash
  • 2,176
Install the hostapd as mentioned above, followed by ap-hotspot, from http://www.ubuntuupdates.org/package/webupd8/trusty/main/base/ap-hotspot and run
Give the correct inter-phase eth0 and wlan0 followed by ssid and pass-phrase.
Start the hotspot by
kraxor
  • 5,627
The file:
http://archive.ubuntu.com/ubuntu/pool/universe/w/wpa/hostapd_1.0-3ubuntu2.1_amd64.deb
Is no longer present on the ununtu.com server. How do I upgrade the hostapd?
this is old post but i stuck in same problem and i solved my problem .
this problem may be occurs with wrong version but in my case if you are using any other network manager tools and service of that manager is running then it may not work ap-hotspot service and it show
solution: stop service of previous network manager tools if you are using default network manager then do
sudo service network-manager stop
or if you using wicd then stop it using
sudo service wicd stop
then you have to start ap-hotspot
pl_rock
  • 11,715
