I'm trying to install a facebook-webapp but the dependency gir1.2-launchpad-integration-3.0 is not found and listed as uninstallable. I have been unable to locate it anywhere except for references to 'Nitro' (which apparently doesn't work either because of this package missing).
Does anyone know what is going on and how I can work around this? I am running Ubuntu 14.04, fresh install and novice user.
qubex
  • 435
gir1.2-launchpad-integration-3.0 repository support has been discontinued
Though you can install using debian installer
It has dependencies which needs to be met that can also be downloaded
(1) liblaunchpad-integration-common
(2) liblaunchpad-integration-3.0
Start from installing liblaunchpad-integration-common
sudo dpkg -i liblaunchpad-integration-common_0.1.56.1_all.deb
Then install liblaunchpad-integration-3.0
sudo dpkg -i liblaunchpad-integration-3.0-1_0.1.56_amd64.deb
Finally install gir1.2-launchpad-integration-3.0
sudo dpkg -i gir1.2-launchpad-integration-3.0_0.1.56_amd64.deb
Et Volia! you are done.
Back.Slash
  • 2,176
