root@localhost:~# apt-get install software-center
Reading package lists... Done
Building dependency tree
software-center :
Depends: python-gobject (>= 3.0) but it is not going to be installed
Depends: python-gobject-cairo
Depends: python-aptdaemon (>= 0.40) but it is not going to be installed
Depends: python-aptdaemon.gtk3widgets but it is not going to be installed
Recommends: gir1.2-launchpad-integration-3.0 but it is not installable
Recommends: sessioninstaller but it is not installable
Asked
Active
Viewed 899 times
Aravinda
- 992
What i believe you have broken package may be while your previous attempt to install software center, I suggest you check the following..
sudo apt-get purge software-center
then try
sudo apt-get update
sudo apt-get install python-gobject-cairo python-aptdaemon.gtk3widgets sessioninstaller -y
As last step
sudo apt-get install software-center
Aravinda
- 992
